Mahindra 7010
   / Mahindra 7010 #1
mike22lr
Cynthiana, KY
Kubota L3750dt
Have a friend with a Mahindra 7010 with a bad motor. Does anyone know of a used motor, one that's been in a fire, or a rebuildable block.
Or any info on repowering with a different motor.
Thanks Mike
   / Mahindra 7010 #2
Thanks Mike
Couldn't you replace with one of the Deere motors they put in the TYM versions?
Look for a salvage 7520
If I might ask, what happened to cause the bad motor? Can it not be rebuilt?
   / Mahindra 7010
I wasn't there when it happened, but ether was involved.
Are you saying a TYM 7520? Did John Deere put them in any construction equipment?
   / Mahindra 7010 #4
TYM built the 7010 for Mahindra. It had the same motor that a Mahindra 7520 has. TYM also built the same tractor for Montana using a JD engine. Or the TYM model also had a John Deere engine in it. Sorry but I don't know If JD had that engine in any construction equipment.
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
Dion 1224 XC Silage Chopper (A50515)
Dion 1224 XC...
Kubota SVL75-2 (A50120)
Kubota SVL75-2...
New in Crate 20' x 40' Hoop Building (A50515)
New in Crate 20' x...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
