Mahindra 7010
/ Mahindra 7010 #1
mike22lr
Cynthiana, KY
Kubota L3750dt
Have a friend with a Mahindra 7010 with a bad motor. Does anyone know of a used motor, one that's been in a fire, or a rebuildable block.
Or any info on repowering with a different motor.
Thanks Mike
/ Mahindra 7010 #2
Thanks Mike
Couldn't you replace with one of the Deere motors they put in the TYM versions?
Look for a salvage 7520
If I might ask, what happened to cause the bad motor? Can it not be rebuilt?
/ Mahindra 7010
I wasn't there when it happened, but ether was involved.
Are you saying a TYM 7520? Did John Deere put them in any construction equipment?
/ Mahindra 7010 #4
TYM built the 7010 for Mahindra. It had the same motor that a Mahindra 7520 has. TYM also built the same tractor for Montana using a JD engine. Or the TYM model also had a John Deere engine in it. Sorry but I don't know If JD had that engine in any construction equipment.
2017 KUBOTA KX057-4 EXCAVATOR (A65053)
2017 KUBOTA...
Wooden Glider Chair (A64557)
Wooden Glider...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
