mahindra 6500 4x4 diff lock
/ mahindra 6500 4x4 diff lock #1
turbinesurgun
have a new 6500 4x4 and when you press diff lock it will kick in and out anyone ever had this problem and if so what was the fix it has to go back to the shop anyway katrina made my barn fall on it, had only had it 2 days.
/ mahindra 6500 4x4 diff lock #2
As far as I know, it should be engaged - at a slow speed - by steping on the petal. Continue depressing the petal as long a the Dif lock is needed. When you take your foot off the petal, and it comes back up, It is disengaged.
Hope it helps.
<font color="blue"> </font> </font><font color="blue" class="small">( katrina made my barn fall on it, had only had it 2 days. )</font>
Major bummer! Can you bring the barn back also? /forums/images/graemlins/tongue.gif
/ mahindra 6500 4x4 diff lock #3
turbinesurgun
Sorry to here about your barn and tractor. As for you diff lock I think you may find that if you step down on it should stay engaged as long as you have a load on it. Once you release the load (come off the throttle or go down the other side of the hill) it will disengage. Hope that helps
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
it will not make both wheels spin. i can actually stand on it with all my 200 pounds of a$$ and it will pick me up seems like 1 spot every revolution barn is a goner 100X50 all piled up on my tractor. i never would have figured this it was made out of 4 inch steel pipe. oh well at least me and my family are alive. god is truly good
/ mahindra 6500 4x4 diff lock #5
turbinesurgun
Sounds like you might want to have your dealer look at it. What do others think?
Happy Tractoring
/ mahindra 6500 4x4 diff lock #6
I take it you don't have loaded rears. My 6000 rears are loaded. I've now got over 200 hrs on it and have yet to have to kick in the diff lock as I can't make it spin a half rotation even pushing a heavy load with the FEL. If you don't have your rear tires filled you should seriously consider it. Bobg in VA
/ mahindra 6500 4x4 diff lock #7
It should drop into place when you press on it. Of course it depents on wheel speed and dirrection. We had a lengthy post on this not long ago, TracLock it may help with understanding how it works. If it never engages then you may need to have it looked at. You could always call your dealer to see if your missing something. I've never been on a Mahindra, so I'm guessing its the same as any I have been on.
i would not have a tractor without water in the tires. I always fill them up first thing when i bring the tractor home. It is something mechanical there is no doubt in my military mind. thanks
211453 (A62131)
211453 (A62131)
(3) Corral Gates (A66408)
(3) Corral Gates...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
