Mahindra 6000 2WD steering fluid leaks
   / Mahindra 6000 2WD steering fluid leaks #1
supersport
My Mahindra 6000 2wd leak steering fluid at the steering column, right under the steering wheel. Any body have/had this problem before??? Thanks in advance for any infor on this.
   / Mahindra 6000 2WD steering fluid leaks #2
Not all that uncommon among tractors with hydrostatic steering. It is usually a small leak and can be corrected by tightening the connection. Be careful not to overtighten it, though.
   / Mahindra 6000 2WD steering fluid leaks #3
Yes just bought a used 6000 2WD with same problem and when I removed the top from the steering box I let the shaft come up off the bottom and now I can' get it to set all the way back down. I plan to put a seal kit in it but can't even find a dealer that has access to a diagram so I can be sure I have it down in the body correctly before reassembly. Any info on a diagram would be very helpful.
   / Mahindra 6000 2WD steering fluid leaks #4
The kit is about $40 at a mahindra dealer! It's most likely the seal in the top of the pump. Had the same problem last year! Took about 4 or 5 hours by myself to fix, hardest part was getting lines hooked back up to pump! Hope this helps!
   / Mahindra 6000 2WD steering fluid leaks #5
Had the same problem last year! The kit is about $30 at a mahindra dealer. It took me about 5 hrs by myself to install it! Hardest part was hooking lines back up to pump! It's really easy to do! Just time consuming! Hope this helps! I had to give them serial # of off tractor , ours is a 2006, and the changed there pump set up in the middle of the year because of this very problem I was told!
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
International 720 6-Bottom Plow (A52128)
International 720...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
