Mahindra 6000 2WD steering fluid leaks
   / Mahindra 6000 2WD steering fluid leaks #1
supersport
My Mahindra 6000 2wd leak steering fluid at the steering column, right under the steering wheel. Any body have/had this problem before??? Thanks in advance for any infor on this.
   / Mahindra 6000 2WD steering fluid leaks #2
Not all that uncommon among tractors with hydrostatic steering. It is usually a small leak and can be corrected by tightening the connection. Be careful not to overtighten it, though.
   / Mahindra 6000 2WD steering fluid leaks #3
Yes just bought a used 6000 2WD with same problem and when I removed the top from the steering box I let the shaft come up off the bottom and now I can' get it to set all the way back down. I plan to put a seal kit in it but can't even find a dealer that has access to a diagram so I can be sure I have it down in the body correctly before reassembly. Any info on a diagram would be very helpful.
   / Mahindra 6000 2WD steering fluid leaks #4
The kit is about $40 at a mahindra dealer! It's most likely the seal in the top of the pump. Had the same problem last year! Took about 4 or 5 hours by myself to fix, hardest part was getting lines hooked back up to pump! Hope this helps!
   / Mahindra 6000 2WD steering fluid leaks #5
Had the same problem last year! The kit is about $30 at a mahindra dealer. It took me about 5 hrs by myself to install it! Hardest part was hooking lines back up to pump! It's really easy to do! Just time consuming! Hope this helps! I had to give them serial # of off tractor , ours is a 2006, and the changed there pump set up in the middle of the year because of this very problem I was told!
John Deere 3025E (A50120)
John Deere 3025E...
2004 Mercedes E320 Sedan (A50324)
2004 Mercedes E320...
2020 Cadillac Escalade 4x4 SUV (A50324)
2020 Cadillac...
Freeland 100 gal Water Trough (A50515)
Freeland 100 gal...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
