Mahindra 5525 Hydraulic Fluid Check?
   / Mahindra 5525 Hydraulic Fluid Check? #1
tower59
Texas
Please forgive this embarrassing question, but the owner's manual just isn't clear to me. Where does one check the hydraulic fluid level on the 5525? There is a red topped plastic cap just behind the driver's seat on the right above the PTO labeled "OIL" and "Misseli" on it. It has no dipstick. Looks like it's in the right place, though.
(1) Where does one check hydraulic fluid?
(2) How does one check hydraulic fluid?
(3) What fluid do I add (from Tractor Supply, if possible)
Many, many thanks!
   / Mahindra 5525 Hydraulic Fluid Check? #2
Hello, I am not familiar with your model. But does it have a sight glass on the left side of the pto?
Nope- no sight glass that I could find.... ???
   / Mahindra 5525 Hydraulic Fluid Check? #4
1: If it doesn't have a dipstick, it will have a sight glass; mine in on the rear, down low, and essentially impossible to see with the backhoe attached!
2: I check mine with all cylinders at about halfway extended, so I don't go too high when they are lowered and more oil is in the gear case (once the level goes above the sight glass, you cannot tell how much fluid is in there!)
3: Tractor Supply has a couple of types of "universal tractor fluid"; I use the stuff labelled "premium".
Ok, figured it out. Turns out that on the 5525 the hydraulic fluid is checked by unscrewing a small bolt just to the right of the gear selector. It has a long dip stick attached and is very difficult to read. There is no label on this bolt, but it is painted red.
   / Mahindra 5525 Hydraulic Fluid Check? #6
Thanks for letting us know that you found it tower!
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53472)
2016 Ford F550 4x4...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
