Mahindra 5525 Hydraulic Fluid Check?
   / Mahindra 5525 Hydraulic Fluid Check? #1
tower59
Texas
Please forgive this embarrassing question, but the owner's manual just isn't clear to me. Where does one check the hydraulic fluid level on the 5525? There is a red topped plastic cap just behind the driver's seat on the right above the PTO labeled "OIL" and "Misseli" on it. It has no dipstick. Looks like it's in the right place, though.
(1) Where does one check hydraulic fluid?
(2) How does one check hydraulic fluid?
(3) What fluid do I add (from Tractor Supply, if possible)
Many, many thanks!
   / Mahindra 5525 Hydraulic Fluid Check? #2
Hello, I am not familiar with your model. But does it have a sight glass on the left side of the pto?
Nope- no sight glass that I could find.... ???
   / Mahindra 5525 Hydraulic Fluid Check? #4
1: If it doesn't have a dipstick, it will have a sight glass; mine in on the rear, down low, and essentially impossible to see with the backhoe attached!
2: I check mine with all cylinders at about halfway extended, so I don't go too high when they are lowered and more oil is in the gear case (once the level goes above the sight glass, you cannot tell how much fluid is in there!)
3: Tractor Supply has a couple of types of "universal tractor fluid"; I use the stuff labelled "premium".
Ok, figured it out. Turns out that on the 5525 the hydraulic fluid is checked by unscrewing a small bolt just to the right of the gear selector. It has a long dip stick attached and is very difficult to read. There is no label on this bolt, but it is painted red.
   / Mahindra 5525 Hydraulic Fluid Check? #6
Thanks for letting us know that you found it tower!
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
