Mahindra 4WD
/ Mahindra 4WD #1
Poncho
Tallahassee Florida
Massey Ferguson 2625 4wd
I went and test drove (?) a Mahindra 5500 4WD on Saturday... got a sneaky suspision this is the tractor I will wind up getting. I kinda crawled under it and looked it over real good... I notice that the forward drive unit where the wheel mounts doesn't appear to be completely sealed like the Kubota.. or did I not see stuff correctly /forums/images/graemlins/confused.gif? If it is open.. will this be a high maintenance area??
/ Mahindra 4WD #2
No it will not be a problem!! It is just a different way of powering the front wheels. Most companies feel the open u-joint system is stronger,compared to the closed bevel-drive. Look around at other tractors,outside of the Asians and Belarus everyone else uses the open-knuckle drive for mfd axles. About the largest hp tractor you can find with the encloseed bevel drive is the Kubota M120 (even Belarus has changed systems on their larger tractors)whereas you'll find open-knuckle mfd axles up to 300 hp.
/ Mahindra 4WD
Thanks for the reply... I've still got a lot to learn about the mechanics or tractors.
/ Mahindra 4WD #4
Even on JDs you can see the U joints on the 5000 series and up to the big ones!
/ Mahindra 4WD #5
one way to think about it is theirs less parts in the axle to break a plus i think! unless they have planatary hubs on front axle then i'm wrong. not that planatarys are bad. either way the diesign is not a problem. ive seen most set ups and not herd any major trouble with any
2022 EZ-GO ELITE...
2015 Ford Escape 4WD SUV (A61574)
2015 Ford Escape...
Iron Bull Golf Cart (A64127)
Iron Bull Golf...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
