Mahindra 4550 won't start
   / Mahindra 4550 won't start #1
lineman697
Mahindra 4550
So I stopped my mahindra 4550 and out it in neutral and turned it off. Got back in a few minutes later and nothing. No dash lights and doesn't try to crank. I verified it was in neutral and still nothing. Check voltage and fuse panel and had 13v. Checked voltage going to ignition and nothing. Check to make sure pto wasn't engaged. I do not have a safety switch on the seat. Ohmed out all fuses and they all Check out. Not sure what it is. Any help is much appreciated.
   / Mahindra 4550 won't start #2
If your fuses are good and you have nothing to the dash you need to trace the wire. Possibly chewed by a mouse somewhere along the line and it finally separated. It's also possible there's a fusible link in there somewhere. Try to score a wiring diagram.
Could it also be a safety switch also
   / Mahindra 4550 won't start #4
Check under the frame of your tractor to see if you have a branch, weed, etc lodged underneath. As lineman697 suggested it could have taken out a safety switch connection. (I hate those things)
I found a blown fuse under the hood by the radiator . There are 2 fuses and a relay right there. Headed to get w new fuse now. Hopefully that works
   / Mahindra 4550 won't start #6
Thanks for posting this.. My '22 4550 would not start recently and it was the 40 amp fuse by the radiator. After I replaced it, dealer said I should put in a 60 Amp Fuse or it will blow again... I am adding a few Maxi fuses to my parts inventory..
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
CATERPILLAR CP44 PADFOOT ROLLER (A52707)
CATERPILLAR CP44...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
2004 MACK GRANITE CV713 DUMP TRUCK (A57192)
2004 MACK GRANITE...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
