Mahindra 4530 won't start
/ Mahindra 4530 won't start #1
murray918
eastern Oklahoma
Mahindra 4530 4wd
I'll start off by saying that I used the tractor last weekend. I went out to use the tractor this morning and I turned the key on and the heater light came on and went off about 45 seconds later. I then turned the key to start the tractor and the starter only clicked. I then checked the battery and it is fully charged 12.91 volts. I then tried it all again, as I turned the key on to initiate the heater and the light didn't come on but a loud humming noise started. I then tried to start the tractor and the starter only clicked again. I then started checking the all connections and they were all good. I then checked the fuses and started pulling them, when I pulled the solenoid fuse and loud humming noise stop and I then tried the start the tractor with the solenoid fuse pulled and the starter still only clicked. Is my solenoid bad or is it my starter or can someone please give me some ideas what else I might need to look into.
Thank you,
Jeff
/ Mahindra 4530 won't start #2
i'd try another battery...just cause it has 12 volts doesn't mean it has the amps to turn the starter, could have a bad cell,
/ Mahindra 4530 won't start #3
Check your ground cable where it connects to the frame. It is a point where corrosion can build up causing a poor connection. Battery voltage would read good. Also check where the battery hot cable connects to the starter for corrosion as well.
/ Mahindra 4530 won't start #4
I agree..Curious as to where you are located in Eastern Ok?
/ Mahindra 4530 won't start #6
Well howdy neighbor.one other thing you might check is all of your safety switches,one on the shuttle and one on your high low selector.
I finally figured it out. Bad cable from battery to solenoid. Was only getting 10.7 volts at the solenoid. Replaced cabled and we are back in business.
Thanks to all of you for your assistance.
/ Mahindra 4530 won't start #8
Glad you got it going. I bet if you cut the insulation off the old cable you'll find some corrosion.
/ Mahindra 4530 won't start #10
remember the voltage readings can fool you without a load..
12volts (unloaded) aint nothing if the voltage drops 50% with load.. Glad you got it fixed, my battery cables need constant attention
That was one of the things that helped me figure it all out. I have a battery tester that has the ability to place a load on the battery. With no load I had 12.91 volts with a load it only dropped to 11.83 but it would drop to 10.7 at the solenoid without a load. I cut the insulation off the cable after I replaced it and it had all kinds of battery acid corrosion.
/ Mahindra 4530 won't start #12
good tester, you would be surprised how many folks think 12v on the meter means full power available
2016 John Deere 6155R (A64119)
2016 John Deere...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
