Mahindra 4530 Stalled
/ Mahindra 4530 Stalled #21
after that id look for a solenoid.
You tried to jump it off or charge the battery? Im sure you have plenty of moisture in the air same as here in Tx. it can mess up connections and let a battery draw much quicker than 6 months. Id charge it up or put some cables to it
I'm looking right now into getting a good charger and a meter to try and solve some of these issues. Tomorrow I will try to jump it off of the other tractor to see what happens.
/ Mahindra 4530 Stalled #23
:thumbsup: great things to have. you wont be disappointed with the purchase
OK update.
13.55 amps to solenoid, and to alternator. Safety switches seem to be working, as I can knock out of gear or engage the pto...and nothing haopens. In both neutrals, and turning the key it still just spins and won't kick over. That's also with 200 amp starter hooked up as well.
Thoughts?? Not getting fuel?
Another update....
It's working.
Ended up taking one fuel line off at a time where it goes into injectors and cranking it until fuel came out. After doing both of them....it cranked right up. Now all I have to do is replace a battery terminal connector that the bolt broke in it.
/ Mahindra 4530 Stalled #26
Good deal
So you saying the alternator is only putting out 13.55? while its running?
Once you fix the connection it could fix the problem but also make sure your belt isn't loose. It should be putting out around 14.5
Good deal
That was not while running.
/ Mahindra 4530 Stalled #28
gotcha. Id check what its putting out while running just to be sure but sounds like your just fine.
Was too excited it was running to think about it, but I will.
UNUSED WOLVERINE QC6-26-15G 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
Volvo EC330BLC Excavator (A61166)
Volvo EC330BLC...
Pat's QH and hydraulic top-link.
Pat's QH and...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
PALLET OF ARMSTRONG CEILINGTILE (A62131)
PALLET OF...
