mahindra 4500 2wd
/ mahindra 4500 2wd #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
i just bought my first tractor, a mahindra 4500 2wd with loader, box blade, 6' shredder. and a trailer for $17895.00
i just have 14 hours on it. this tractor really really has to warm up or it will sputter when you throttle up. once the temp gauge gets up to as far as it goes " about 1/4 of an inch into the green" then it runs great.
also when i got the new trailer it had used tires on it, the dealer said the sputtering and the used trailer tires are normal. i would send a picture but i havent figured that out yet.
/ mahindra 4500 2wd
i would like to add that i do love this tractor, i was discing about 5 acres of my land the other day and the sound this machine makes is cool, and the ride is a smooth that only many thousands of pounds of steel can give.
/ mahindra 4500 2wd #3
Congrats on the new 4500! I don't think the "sputter" when cold is natural. Diesels aren't built that way. True, you shouldn't be peggin' it until its been running for a while but my 6000 could take an hour to get into the green on the temp guage. I think the dealer needs to check the injection pump. It may need to be turned "up" a tad. Enjoy! BobG in VA
/ mahindra 4500 2wd #4
Bob could very well be right about the injector needing to be jacked up a few notches to stop the sputtering. My 4500's a bit older than your's and on immediate startup - it sputters a little bit also but within 3 minutes - it seems ready to work. As anyone will tell you...always let it warm up a few minutes but if I left mine to idle until the temp gauge showed anything, I'd be waiting for 1/2 the day.
As for the used trailer tires...it happened to me also but instead mine were recaps on a single axle 2,000 lb trailer. Never again! Both tires went out of round(possibly a slipped belt in the radial) but none the less - it cost me more in the end. Later on, I bought a new 30', triaxle trailer and it came with new tires that I need to haul my tractor and accessories around on. I feel a lot safer on the highway just knowing that these tires were made for the job. By the way - sounds like a good deal overall on your purchase. Best of luck to you and enjoy! Clyde
/ mahindra 4500 2wd
the dealer said, and also the head mechanic, that the e.p.a. made them add a sensor that measures the temp around the engine and advances the timing untill it reaches 104 degrees, the mechanic sais more like 140. all i know is i dont like it. i was running it on a cold day and after shredding 20 acres i stopped at the house and let it idle for 10 or 15 minits, got back on and it had cooled enough to sputter again.
/ mahindra 4500 2wd
my trailer is a 2 axil, 7000 pound, im sure this tractor with loader and shredder is over 6000 pounds. what kind of tires would you recommend?
/ mahindra 4500 2wd #8
fish,my 4500 is a year old,when i was at my dealer test driving it ,it also had a sputter.the dealer also said because epa required this timing setting it was sputtering,but,that they would readjust it before i picked it up,they did and it runs great.also i don't know what your shredder weighs but the tractor comes in at 4752lbs. w/o the loader.by the way what loader do you have?
/ mahindra 4500 2wd
its a ml260 loader, it looks pretty heavy duty, the sub frame looks like it should be on a tank.
/ mahindra 4500 2wd #12
I bought a 4500 last year same dealer and it runs great will only sputter on startup for a sec and that is only on very cold days .Would buy the tractor again right now I do everything from dirt work to hay baling. 4500 loader,boxblade,6ft mower.
/ mahindra 4500 2wd
ive just had mine for a month, if i had it to do over again i would buy the same tractor from the same dealer. i did alot of shopping for along time and this was the best in my area, there is another good dealer closer to me but he dont sell mahindra tractors.
/ mahindra 4500 2wd #14
Just curious. What would have been the difference in price for the 4wd model. It seems up here in Washington the prices are much higher than what has been quoted from other owners. Makes me think I should travel to get one.
/ mahindra 4500 2wd
im at work, i have a price list at home, but if i remember right 4wd was $4600.00 extra. i couldnt justify it for me but ill bet that new 4320 or 4230 would be worth it.
/ mahindra 4500 2wd #16
If you are in the market for a Mah, let me suggest you call J 5 Tractors @ 936-396-6032 -- they are located in Normangee, TX across the street from the largest Kubota dealer in the US and they seem to really cut prices. I am buying a 4530 from them and they had the best price around! I am from Louisiana so the "no sales tax" really sealed the deal for me.
/ mahindra 4500 2wd
4530, thats it, i only had $4500 to put down, if i would have had double that i would have bought the 4530.
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
9ft. Kewanee 3 Point Blade (A65640)
9ft. Kewanee 3...
2015 Caterpillar 304E (A64126)
2015 Caterpillar...
2015 Chevrolet Silverado Pickup Truck (A62613)
2015 Chevrolet...
Vermeer S450TX (A64126)
Vermeer S450TX...
