Mahindra 4110
/ Mahindra 4110
mboulais, we have about 75 acres on the farm, most of which is hilly, to downright steep; thus my desire for the MFWD. Most of the tillage type of work would just be for gardening type stuff, no big jobs. The heaviest work would be handling round bails that I feed to our horses.
The horses are my primary farming endeavor.
I really pay attention to the lift capacities as it tells a lot about the strength of the hydraulics system. I will be using a 6 foot bush hog, 6 foot disk, a fertilizer spreader with about an 800 lb capacity, etc. These are well within the limits of most CUTs of the 40 hp size; but the Mahindra 4110's specs put them well within the limits. I also will be using a bail spear on the back, as well as using the loader spear.
Currently I am using my father-in-law's 4000 Ford for these tasks, but it is not as nimble as the MFWDs on the hills for bush hogging. It has no loader for helping to clean out the barns, and it really is just about too big for those chores if it did have a loader attached. Because of the size factor in working in the barn hallways the larger CUTs are the smallest sized utilities are mainly what I am looking at. Right now the muffler needs to be taken out to push out the shed where I feed my horses in the pasture their grain. The makes for a lot of diesel fumes, and I want to avoid doing that in the future.
I plan to put up new fence all the way around the farm next summer, so the independent PTO is going to be handy for use with a PHD, and something I consider a must over the transmission driven PTOs on some of the CUTs.
There is a NH square bailer that is used on the farm for hay, but the Ford 4000 is here for that. The tractor I get may be used for raking and mowing hay with a sickle bar mower. The 4110 should be well up to these tasks as there have been much smaller tractors used for those tasks in the past in this area, like an Allis Chalmers B, Farmall Super A, etc. It doesn't take a lot of hp or size to rake hay or mow with the sickle bar mowing machines.
Price will play a big role in my ultimate decision. There is a Kioti dealer about 2 hours away that has a price of $19,400 on their DK45 w/FEL. I am hoping that more local dealers will be able to top the prices on the Mahindras. I really want to stay under that $20,000 mark. There have been some dealers crop up locally who sell the McCormicks, but I have yet to get a price on them, but would definitely consider them as the fit and finish look pretty good.
/ Mahindra 4110 #12
I think you're gonna be pushing it. The old way of calculating "plowability" is approx 1" of plow for every available HP. If you have 35HP at the drawbar you can pull up to 35" of plow. I have a feeling those are 14" plows on your 3 bottom. Don't remember ever seeing 3--12" bottoms on one. Now, especially if you have clay soil deduct some pull. I hope the 4110 will pull it but count on using all 4 wheels to pull it. PS you got fluid in the rear tires?? If not I think you can forget it.....Just my $.02 worth from someone that has plowed more acres than I'd like to recount. BobG in VA
/ Mahindra 4110 #13
PS. Your Ford 4000 will pull your plows. BobG in VA
/ Mahindra 4110 #14
If you don't mind a short drive to Alabama, we can make you great deal on a 4110... they are going up in price after the first.
Steve
Artec Tractor & Equipment
(205) 384-9570
/ Mahindra 4110
</font><font color="blue" class="small">( If you don't mind a short drive to Alabama, we can make you great deal on a 4110... they are going up in price after the first.
Steve
(205) 384-9570 )</font>
Steve, what kind of current prices do you have, and what kind of price will it be after the first of the year?
/ Mahindra 4110 #16
We are not allowed to advertise price on the internet, so you will have to call us or email us: info@artectractor.com
Thanks,
Steve
(205) 384-9570
/ Mahindra 4110
Steve, I sent the email to the address you gave.
/ Mahindra 4110 #18
I just went out measured them, they are 12" plows. Yes the rear tires are loaded. I personally don't think anyone should own a tractor with FEL without loaded tires. If there wasn't any frost in the ground I would plow a couple of furrows just to prove it. I'm kind of stubborn and competetive.
/ Mahindra 4110 #19
Did you measure from top to bottom of the moldboard or across the beams?? I noted above that you said they were "...12 inches deep". Remember, plows are measured across the beam; or from the outside of one beam (thing that holds the plow in position) to the inside of the next one. If that is 12", I gladly conceed. As you may note, I'm somewhat competitive myself. BobG in VA wouldn't try pulling a 4 bottom plow with his 6000 4WD but do believe it will pull a 3 bottom quite well in VA clay.
/ Mahindra 4110
</font><font color="blue" class="small">( I just went out measured them, they are 12" plows. Yes the rear tires are loaded. I personally don't think anyone should own a tractor with FEL without loaded tires. If there wasn't any frost in the ground I would plow a couple of furrows just to prove it. I'm kind of stubborn and competetive. )</font>
Two and three bottom 12" plows used to be pretty popular. The old tractors with low horsepower, but loads of compression, torque & weight, would pull two and three bottoms easily with an under 40hp engine. The only thing I can see stopping the 4110 from plowing with your plows would be not getting adequate traction due to weight. The MFWD should help in that respect.
Electric Golf Cart (A56859)
Electric Golf Cart...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
Industrias America Loading Ramp (A60463)
Industrias America...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
