Mahindra 3510 will not shut off with key???
   / Mahindra 3510 will not shut off with key??? #21
that works just as good! lol there were a few that only offered the electric kill also
I thought all the 3510 and 4110 tractors had the manual shutoff?
   / Mahindra 3510 will not shut off with key??? #22
   / Mahindra 3510 will not shut off with key??? #23
I wish they sold the kits so you could put those old tech shutoffs into newer tractors and toss the solenoids... :)
   / Mahindra 3510 will not shut off with key??? #24
LOL that's no lie! I guess they needed to use the space for something else
   / Mahindra 3510 will not shut off with key??? #25
Just another thing to jack the prices up with.
   / Mahindra 3510 will not shut off with key??? #26
If you have ever had a diesel engine "run away", you will be willing to stop the engine at any costs, before it grenades! Last one I had "run away" was with an automatic transmission that required the truck to be at idle before it would engage into gear, so popping it into gear to stall it was not an option (although I tried). Had to stand there with the keys in hand, and watch it wind out so fast I thought it was going to come apart before it finally decided to shut down. Never any fun!!
David from jax
   / Mahindra 3510 will not shut off with key??? #27
David from jax
put in high drop the loader in the ground and let it have the full forward pedal
   / Mahindra 3510 will not shut off with key??? #28
The diesel engine in question was in a tractor trailer, with an automatic that required the truck to be at idle before it would go into gear. So... no loader to drop, no full forward pedal to let it have.
If the seal between the turbo and the oil that cools it goes out, then the oil will be sucked into the turbo, and atomized, so basically the engine starts running off of the oil that is coming from the seal and the more oil that comes in, the faster the engine runs, which causes more oil to be sucked in, and it becomes a vicious cycle. Typically you have to choke the air intake, or starve the engine of fuel, or stall it. If you can't stall it, and it is feeding off engine oil, choking the air flow is the only other option.
David from jax
   / Mahindra 3510 will not shut off with key??? #29
David from jax
Yup stoping the air flow is the only way to shut down one sucking oil from the leaky turbo seal. The VW TDI engines have a ASV valve. It stands for anti shudder valve. It's a valve in the intake that closes when you shut the engine off. It stops the air flow, thus stopping the engine quickly not letting it rumble like the 80's diesels did for a couple seconds after you shut them off. The ASV valve in theory would kill a runaway VW when you shut it off.
   / Mahindra 3510 will not shut off with key??? #30
David from jax
Ah my bad I thought we were talking about an HST tractor
Ford 641 Workmaster (A50514)
Ford 641...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
