mahindra 3510 which battery
   / mahindra 3510 which battery #1
nworbekim
southern Kentucky, USA
mahindra 3510
time to get the little feller ready for summer work... the original battery appears to be shot, what is a good replacement that won't break the budget? I bought a new battery for my cub tank last fall and I thought it was terrible how much they'd increased in price since the last one. I can't imagine how much this one will cost me.
   / mahindra 3510 which battery #2
I can' tell you which is best (I think there's a lot of subjectivity involved) but but be prepared for nearly a $150 bill. :(
   / mahindra 3510 which battery #3
In my opinion, the best battery for the money is an OPTIMA. Car, Marine, & RV Batteries | OPTIMABATTERIES
The REDTOP® high-performance AGM battery is the ultimate starting battery designed to deliver a powerful burst of ignition power for a reliable start-up every time, whether it's used as a truck battery, automotive battery, or for other applications. The REDTOP will outperform and outlast traditional batteries in demanding cranking/starting applications. With impressive high-power delivery and extreme resistance to the most common causes of battery failure, the REDTOP is ideal for trucks, SUVs, hot rods, street cars and other applications that require a spillproof starting battery. Its reputation as a truck battery or automotive battery is unsurpassed.
yah, this one's shot... charged it all night and it's still down. off to the battery store.
it lasted 5 years I think. about all that can be expected these days I guess.
btw, is the sylinoid (sp?) that shuts the engine down when you turn the key off, dependent on battery power? we jump started the tractor yesterday, but it wouldn't turn off with the key. I had to pull the kill switch. I assume it is dependent on 12v, but I want to ask, just in case.
   / mahindra 3510 which battery #5
what killswitch? They either had a manual kill or an electric kill.
   / mahindra 3510 which battery #6
Id double check your alternator to see if its pumping out enough juice
   / mahindra 3510 which battery #7
at five years, it's time to go.
   / mahindra 3510 which battery #9
Only 5 years from a battery is terrible IMO.
I expect and generally get near double that out of a battery.
Very well can get much more than that too. All depends on how the upkeep was on the battery.... connections, wire condition, alternator, if it was pre charged before being used.. how many times it was ran down to nothing... exposure to weather... a lot plays into the life of a battery..
   / mahindra 3510 which battery #10
I'm 69 years old and on average I've always experienced 5 years to be about it. Sure some last longer, by a little, but not many. I figure I'll change them at 5 just so I don't get 'left beside the road'.
Maybe a warmer section of the country increases life.
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
NEW Fork Extensions (A53002)
NEW Fork...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
