Mahindra 3510 maintenance
   / Mahindra 3510 maintenance #1
jimmycrouch
Mahindra 3510
I have inherited a Mahindra 3510 and have little to no knowledge about this tractor. The items that I need help on are the following:
1. How to check the fluid levels for oil, hydraulic and transmission?
2, How to engage the PTO? I have a digger attachment, but cant get the PTO to engage.
I have found two fluid indicator sticks on the back of the tractor. I am assuming that these are for the hydraulic and transmission? I do not see a place to fill either fluid?Can someone help me with this? Maybe a video or similar?
Thank you.
Thank you. That is very helpful! I have a lot of reading to do!
Are the levers shown as B and A in the photo used to drop the digger attachment (B) and spin the digger attachment(A)?
   / Mahindra 3510 maintenance #5
Those are the rear remote control levers to operate whatever implement you have attached to the hydraulic connectors above the 3 pt hitch. My 4110 came with only one set and uses the lever closest to the seat. I tried for YEARS to get the components from Mahindra for the second set and they could never source them for me so I could have 2 sets of remotes. If your tractor has both, feel extremely lucky !!
   / Mahindra 3510 maintenance #6
The pto shaft is what creates the spinning.
You should have two switches plus a lever to engage the pto.
Both of these switches need to be "on" or else the shaft will not turn.
2015 Ford F-550 4x4 Knapheide Service Truck (A50323)
2015 Ford F-550...
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
P.T 8' Offset Disc Harrow (A50120)
P.T 8' Offset Disc...
Rhino 484 84in Rotary Cutter (A50322)
Rhino 484 84in...
2018 INTERNATIONAL LT625 SLEEPER (A52141)
2018 INTERNATIONAL...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
