Backhoe Mahindra 3505 di engine needed
   / Mahindra 3505 di engine needed #1
Donhicks1
Mahindra 3505 di
I. Have the mahindra 3505 di has hole in lower block needs block or engine if can help please let me know in desperate need
   / Mahindra 3505 di engine needed #2
Could it be "cold stitched", i.e. is it a just hole in a cast iron wall ?
Cast iron CAN be welded, or even brazed.
If you decide to replace it figure who it is actually MADE by, e.g. Yanmar, Mitsubishi, etc.
Then you have more options for sources.
   / Mahindra 3505 di engine needed #3
Have you tried contacting a Mahindra dealer?
You may also wanna take a look at tractorhouse.com and see what they have to offer under "dismantled machines" at the bottom of the page. Do a search for your model.
I'm curious to know what happened to the engine...
I bought it like that it it had a hole beside the starter 2 inch round hold I think a rod came through it was running the rod was tied to the starter bracket. And the fuel line was cut off to number 3 cylinder that's where hole is Lightning struck it burnt
Harness reside bat to starter now will not crank sprayed with ethane no crank
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2011 TAKEUCHI TB285 EXCAVATOR (A52707)
2011 TAKEUCHI...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft Insulated Bucket Truck (A55852)
2012 Freightliner...
