Backhoe Mahindra 3505 di engine needed
   / Mahindra 3505 di engine needed #1
Donhicks1
Mahindra 3505 di
I. Have the mahindra 3505 di has hole in lower block needs block or engine if can help please let me know in desperate need
   / Mahindra 3505 di engine needed #2
Could it be "cold stitched", i.e. is it a just hole in a cast iron wall ?
Cast iron CAN be welded, or even brazed.
If you decide to replace it figure who it is actually MADE by, e.g. Yanmar, Mitsubishi, etc.
Then you have more options for sources.
   / Mahindra 3505 di engine needed #3
Have you tried contacting a Mahindra dealer?
You may also wanna take a look at tractorhouse.com and see what they have to offer under "dismantled machines" at the bottom of the page. Do a search for your model.
I'm curious to know what happened to the engine...
I bought it like that it it had a hole beside the starter 2 inch round hold I think a rod came through it was running the rod was tied to the starter bracket. And the fuel line was cut off to number 3 cylinder that's where hole is Lightning struck it burnt
Harness reside bat to starter now will not crank sprayed with ethane no crank
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
Quick Attach Pallet Forks (A47384)
Quick Attach...
CATERPILLAR D6 LGP HI-TRACK CRAWLER DOZER (A51242)
CATERPILLAR D6 LGP...
