Mahindra 3316 HST loses power
   / Mahindra 3316 HST loses power #1
daneb23
Milan, TN
Mahindra 3316HST
Starts but loses power then cuts out; at first would run 20-30 min before losing power; is not overheating; replaced fuel pump and filter; no sign of water/coolant in oil, no bubbles in coolant, no moisture coming out of exhaust; tried removing fuel cap to make sure it was venting; tried removing air hose at intake manifold to be sure air intake adequate; get black smoke at start up, but not after, this was typical before started running poorly; tried seafoam and diesel 911;
   / Mahindra 3316 HST loses power #2
Duplicate post as you also posted this in the general "parts/repairs" section. I responded to your post in that section. It's best to just post a question in one section of the forum. I'd link to that other response, but I'm not sure how! Welcome to TBN, and best of luck solving this problem.
   / Mahindra 3316 HST loses power #3
Sounds like you may have junk in the tank plugging up the hole.
Turn off the fuel, remove the fuel bowl, use the bowl or a can under the filter housing, turn the fuel on and see if it gravity feeds a good stream of fuel? if it just trickles out its got something plugging up the outlet at the bottom of the tank.
Thank you! I'm removing this post.
Thanks to both of you. Must have been a clog fuel hose. Cleaned everything out and I'm back in business.
   / Mahindra 3316 HST loses power #6
Glad you are going again. BTW, your first post was well done. You included a lot of facts, and that was very helpful.
   / Mahindra 3316 HST loses power #7
You mentioned that it blows black smoke at start up , Does it still do that ? Mine blows black smoke when starting up but clears right up when it starts .
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
EZGO (A50324)
EZGO (A50324)
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
