Mahindra 3016 Advice
/ Mahindra 3016 Advice #1
nj1026rguy
COLUMBIA
2012 JD 1026R
I am looking a purchasing a used 2011 3016 HST with loader and backhoe (500hrs). I currently have a JD 1026r and looking to upgrade to a larger machine with more loader lift capacity.
Eventually would like to add a grapple bucket as I am clearing about 8 acres of fallen timber and brush.
A few questions;
Does anyone have any experience with the loader capacity? Will I see a big difference between my JD?
Also, what would be a reasonable price to pay for this?
I appreciate your feedback and help.
/ Mahindra 3016 Advice #2
The 3016 was rebranded the 15xx series. Most folks have been very happy with these Mitsubishi machines.
Here is the specs for the 3016. This website probably has the specs for your JD as well. The FEL on my 1538 has served me very well. I have a grapple, snow blade and forks for my machine. The FEL has been good- plenty of lift etc to carry logs, rocks etc.
The MSRP price is also listed on the link below. The deduction for used is probably offset by the BH. Anything near that would be fair in my opinion. It was my experience that finding a used machine that met my needs and was underpriced was near impossible- if I did find one the shipping ate up any savings. After a year of looking near daily I ended up buying new. Adding the BH into the equation only makes this worse- I'm guessing a BH is only on 1:100 sold.
Good luck- if the 3016 was treated right this will be a great machine!
TractorData.com Mahindra 316 tractor information
/ Mahindra 3016 Advice #3
It will be a night and day difference. The oak stem in the picture weighs about 1700lbs. The same stem being walked over to the splitter just to show its length.
Thanks Arrow for the pictures. Firewood will be a major task for the tractor.
Any thoughts on what would be a reasonable offer? It has about 500 hours on it.
/ Mahindra 3016 Advice #6
Don't know if this helps or not but I paid $24k for my new 3016 hst with loader and hoe in 2014. It has been a flawlessly running workhorse for me. I'm amazed at the lift capacity. When the 3016 was renumbered the 1526, people were searching all over the US for one. They are one of the best made tractors of all brands in that size range. If you feel good about the price, get it.
/ Mahindra 3016 Advice #7
Good when buying, bad when selling but Mahindra's for a lot of little reasons, do not hold their value like Kubota. Look on Tractor House etc, and price down from there. 3016 is good tractor.
Thanks Mike. I'm checked out tractor house and only found 1 that included the backhoe for $19.9k. Seems like the average for tractor and loader are around $13.5k. I'm thinking along the lines around $17k. Not sure if that's a lowball offer or not
I'm also going to look at it Wed afternoon. Anything I should pay particular attention too?
/ Mahindra 3016 Advice #10
Wiggle and try all the mechanical stuff.Take look underneath, operate it for 15 minutes. Try diff Lock.
Fluids, service records? Sniff oils. Look at filters.
Electrical Check battery for the sulfuric acid build up. Turn everything on off. check for loose damaged wiring, especially seat switch.
Is it pink yet?
Is it pink yet?
Great thanks. No I attached a picture a few posts prior.
/ Mahindra 3016 Advice #12
3016 doesn't have a seat switch and don't turn pink. Mine hasn't.
Any thoughts on what the backhoe would be worth? I am having some troubles finding the MSRP for them new.
/ Mahindra 3016 Advice #14
It seems to me I remember seeing a number around 7k.
/ Mahindra 3016 Advice #15
Btw, my spec sheet says the fel will lift 1650 lbs TO FULL HEIGHT at the pivot pins. That means more than that lower heights.
/ Mahindra 3016 Advice #16
Sorry, for some reason I can't edit my last post.
That lift capacity will lift your whole tractor to the heavens. The tractor by itself is 1000 pounds heavier than your Deere. It's a whole different class of machine than yours.
Thanks for the input. It would make my life a **** of a lot easier with a bigger machine.
What are your thoughts about a price? I am thinking around 15-17k would be a reasonable offer.
/ Mahindra 3016 Advice #18
If that machine cost 24-25 like mine, and you offer 15, that's 10k of of a 25k price or about 40 percent. Seems like a big drop in price for a machine with those hours. But I don't know. I'm just thinking out loud.
The only reason I am saying that is because the average listed price on tractor house is 14,000 for a machine with 295 hours not including the backhoe.
Take into account of he 200 hour difference and the backhoe I think 17k would be a reasonable offer.
So I went and saw the tractor this afternoon. Great looking machine, had 600 hours but couldn't strike a deal. They were looking for $22,500, I think that's alittle overpriced.
Oh well, on with the shopping
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2007 FREIGHTLINER...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2017 CATERPILLAR 305E2CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
