Mahindra 2816 Help
/ Mahindra 2816 Help #1
talon636
Atlanta, GA
Mahindra 2816
I have a Mahindra 2816 that the pto won't lift. The bucket does, but the bush hog won't come up. I have checked to make sure the valve is opened all the way and top off the fluid. Any other ideas?
Thanks
/ Mahindra 2816 Help #2
Hydraulics:
Type: open center
Valves: 0 or 1
Pump flow: 7.8 gpm [29.5 lpm]
Steering flow: 3.5 gpm [13.2 lpm]
If FEL works, you have flow through all the valves to tank.
You are talking about the 3pt will not lift a bush hog.
Is the bush hog to heavy?
If you installed a hyd gage in a tee in the IN port of the FEL valve, you could monitor and trouble shoot the hyd system.
If the gage were installed and you raised the lever, you would see the pressure required to raise the bush hog.
If your 3pt valve is good, then the seals on the 3pt cyl is bad and bypassing the fluid.
Do you have hyd input going into the 3pt?
Some people using a BH, will bypass the 3 pt system.
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2018 Monroe Towmaster TC-16 10 Ton T/A Tag Trailer (A61573)
2018 Monroe...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
