Mahindra 2638 hst front diff.
/ Mahindra 2638 hst front diff. #1
apeckham
Mahindra 2638
Hi all, I own a 2019 2638hst and to me the front differential seems very noisy. This is while running it in mid range 2 wd . I checked the oil in it and it was ok.
Does anybody else have this issue with their tractor?
/ Mahindra 2638 hst front diff. #2
Mine seems noisier if in 4wd and moving in mid range but in 2wd is pretty quiet.
/ Mahindra 2638 hst front diff. #3
Mine "whines" at lower engine RPM's and under load (uphill, or towing something heavy). If I ramp up the RPM's to 1600+ it's not near as noticeable. I think it's inherent to an HST, since everything is run by hydraulics.
/ Mahindra 2638 hst front diff. #4
don't think a differential is hydraulic-
Also this is one good thing about a manual trans vs hyd- it might bump a little going into gear, but gear drive! Only thing that is hydraulic are the 3pt arms and FEL
/ Mahindra 2638 hst front diff. #5
What’s the maintenance history? Might be worth changing the oil. If UTF switch to a gear lube…or vice versa.
/ Mahindra 2638 hst front diff. #6
My Mahindra requires using Trans-hyd oil in front differential, gear lube might not be good if you live in cold area. Also have you followed the schedule for changing the oil?
2020 Hyundai Sonata Sedan. (A61574)
2020 Hyundai...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
TAYLOR WAY 16' DISC HARROW (A64276)
TAYLOR WAY 16'...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
