Oil & Fuel Mahindra 2615 Gear - Basic maintenance question
   / Mahindra 2615 Gear - Basic maintenance question #11
It appears to be leaking where the hose enters the connector.
I assume you mean the junction of the crimp onto the hose and its crimped on connector if so then Yep, you will have to replace.. Remember when the tractor is running and fluid is sent to that hose from the control valve (joystick valve) DO NOT bring your body any where near that leak, You might not see that fine stream of fluid but it can penetrate your skin and do really really bad things to you by injecting you with the fluid. Always check for leaks with a piece of paper held safely away from the suspected leak site. Just being the safety police here, but I would sure hate for you to be injured because you did not know about pressurized hydraulic fluid leaks.
Yes, it's at the junction - so looks like a replacement hose is in order. And thanks for the danger alert - I was unaware there was a risk. Does anyone know if I have to use an OEM part or can I use a generic hydraulic 44" hose (or maybe a 48" which seems to be a more standard size)with 1/4" fittings - or maybe a hose from the local JD dealer?
   / Mahindra 2615 Gear - Basic maintenance question #13
Most people just take them to a hydraulic hose shop and say. "would you please make me another one" Just make sure it has the correct fittings and length.
Fluid Injection Injury - YouTube
Well, that was a disturbing video. Glad to hear I can get the hose from any local shop that works on those types of items. I'm replacing a short hydraulic hose on the lift arm. With the tractor off and lift lever moved back and forth to bleed off latent pressure, can I just disconnect the fittings and remove the hose? Or will fluid continue to drain out? Or is it still under pressure?
   / Mahindra 2615 Gear - Basic maintenance question #15
Go to your local Tractor Supply Store for the hose. It will be considerably cheaper than getting one made.
Ask me how I know !
   / Mahindra 2615 Gear - Basic maintenance question #16
One change you won't read about in the owners manual is the front axle fluid now calls for the same hydraulic fluid you use in the tractor. It is also less expensive than gear oil.
   / Mahindra 2615 Gear - Basic maintenance question #17
Yes, just as you described it will be safe, and very little fluid will dribble out.
   / Mahindra 2615 Gear - Basic maintenance question #18
Yes the video was ugly, and so are the wounds that can happen from high pressure fluid injection. Aren't you glad you know about that little tidbit now?:)
Thanks everyone for all the good information. I stopped by the local JD store this morning and they made a hose for me in a few minutes (hat tip to you oldpilgram). BH is off and field mower is on and was able to do a few test runs with it on the five acres last night before dark. Grease gun arrives tomorrow and I'll use the weekend to go through the various fluids.
   / Mahindra 2615 Gear - Basic maintenance question #20
Good luck with everything, and if we can help with anything let us know. Don't be a stranger, come on back and let us know how things are going.:thumbsup:
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2149 (A58376)
2149 (A58376)
SKID STEER GRAPPLE BUCKET (A58216)
SKID STEER GRAPPLE...
1191 (A56859)
1191 (A56859)
