Mahindra 2615 clutch noise question
   / Mahindra 2615 clutch noise question #1
Obiwan
Selma, OR
Ford 800 & Mahindra 2615
I have been visiting this site and finally got around to joining.
I used information I gathered from this site to choose a Mahindra 2615 used with under 200 hours, FEL and BH.
After over 20 years on a Ford 800, I found this little guy a joy to drive.
After a couple of hours, it started making a high pitch squeal when I pressed the clutch in I concluded it was a throw out and took it to the dealer. They split it and found one disk had a severely worn spline andthe other had rattling springs. They replaced the disks, throwout and pilot bearings, as well as installing a slug in the end of the crank to keep the shaft spline from walking forward. It was discovered the reason for the wear is a couple owners ago, the frame to engine bolts came loose and there was movement between the engine and tranny.
My question is it still makes the same squeal when I press the clutch pedal, but stops when I get it all the way down. Any ideas?
Thanks in advance for any help.
Obiwan
   / Mahindra 2615 clutch noise question #3
Welcome to TBN!
I moved your post to the Mihindra forums. You'll get a much better response here.
   / Mahindra 2615 clutch noise question #4
I do not know. I have a 2006 2615 with over 900 hours. Has the clutch ever been replaced?
As I said in the initial post above, the dealer replaced both clutch disks, throwout and pilot bearing, thanks.
   / Mahindra 2615 clutch noise question #6
I would have to take it back to the dealer and let them get it right
   / Mahindra 2615 clutch noise question #7
New T/O bearings with defects are not uncommon; they are often sealed-type and nearly impossible to inspect or pack before installation like on typical tapered roller bearings on wheel-hubs. 100% of the T/O bearings I have seen (to the best of my memory :D) have been sealed.
Sometimes they quit squeaking on their own; most of the time they do not.
X2 on taking it back to the dealer.
Just my $.02
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
