Mahindra 2615 clutch noise question
   / Mahindra 2615 clutch noise question #1
Obiwan
Selma, OR
Ford 800 & Mahindra 2615
I have been visiting this site and finally got around to joining.
I used information I gathered from this site to choose a Mahindra 2615 used with under 200 hours, FEL and BH.
After over 20 years on a Ford 800, I found this little guy a joy to drive.
After a couple of hours, it started making a high pitch squeal when I pressed the clutch in I concluded it was a throw out and took it to the dealer. They split it and found one disk had a severely worn spline andthe other had rattling springs. They replaced the disks, throwout and pilot bearings, as well as installing a slug in the end of the crank to keep the shaft spline from walking forward. It was discovered the reason for the wear is a couple owners ago, the frame to engine bolts came loose and there was movement between the engine and tranny.
My question is it still makes the same squeal when I press the clutch pedal, but stops when I get it all the way down. Any ideas?
Thanks in advance for any help.
Obiwan
   / Mahindra 2615 clutch noise question #3
Welcome to TBN!
I moved your post to the Mihindra forums. You'll get a much better response here.
   / Mahindra 2615 clutch noise question #4
I do not know. I have a 2006 2615 with over 900 hours. Has the clutch ever been replaced?
As I said in the initial post above, the dealer replaced both clutch disks, throwout and pilot bearing, thanks.
   / Mahindra 2615 clutch noise question #6
I would have to take it back to the dealer and let them get it right
   / Mahindra 2615 clutch noise question #7
New T/O bearings with defects are not uncommon; they are often sealed-type and nearly impossible to inspect or pack before installation like on typical tapered roller bearings on wheel-hubs. 100% of the T/O bearings I have seen (to the best of my memory :D) have been sealed.
Sometimes they quit squeaking on their own; most of the time they do not.
X2 on taking it back to the dealer.
Just my $.02
JOHN DEERE 5205 TRACTOR (A51406)
JOHN DEERE 5205...
2014 Lodal EVOMAG20U300 Side Loader Garbage Truck (A48081)
2014 Lodal...
2019 International DuraStar 4300 S/A Cab and Chassis Truck (A48081)
2019 International...
2010 Volkswagen Passat Sedan (A50860)
2010 Volkswagen...
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
2004 Hyundai Santa Fe SUV (A48082)
2004 Hyundai Santa...
