Loader Mahindra 26 Max XL
   / Mahindra 26 Max XL #1
jgeddes
New Park
Mahindra 26 Max 26XL 4WD HST
I'm new to this forum and wanted to get some feedback regarding my Mahindra 26 Max XL. The machine is just over a year and have half old and has around 330 hours. Both of my loader mounting brackets have cracked at the cylindrical body with various bolts coming loose or missing. Some bolts have even broken in the housing. I had not previously checked for loose bolts. The Mahindra dealer took pictures and was told by Mahindra customer service that the repair would not be covered and would costs around $2400 to repair. Any thoughts?
   / Mahindra 26 Max XL #2
You are supposed to check for loose nuts and bolts often and they say so in the manual and also say damage from it will not be covered. Either pay the money for the repair or learn to weld and chalk it up as a lesson in life. After it's fixed, check those nuts and bolts like you're supposed to do. Put some witness marks on them so you can tell at a glance if any have moved. Also check the lug nuts on your wheels.
   / Mahindra 26 Max XL #3
Ouch. So much for that 7 year warranty.
Sounds like the dealer didn't' check the bolts when they set it up and neither did you. Still seems like a lot of damage for that many hours. Were you just abusing the loader?
   / Mahindra 26 Max XL #4
If he has that many hours on it it was probably a 5 year warranty like mine. Here I am only a few hours over the 50 and now the warranty is an extra two year. The 7 year is a new thing. They keep one upping each other. I'll see your 5 year and do 6 on mine, then they come back with 7. Pretty soon they'll all be at 12 years and counting. LOL A regular warranty pissing contest.
I'd be happy with better manuals and such since they can always wiggle around doing real warranty work. Warranty can be a lot like slimy lawyer stuff. Maybe a better prep program before new tractors are delivered to customers would help too. Make all the distributors and dealers conform to a standard prep program and not leave it to chance.
Still just because they give you a warranty doesn't mean they took you to raise.
   / Mahindra 26 Max XL #5
Hate to hear that - maybe post some photos so we can help you find a suitable repair.
   / Mahindra 26 Max XL #6
Mahindra 5 year warranty Is for certain internal parts of the motor, I think the drivetrain is 2 years and the loader is 1 year. That doesn't count the wiggle factor that the manufacturer will try to find an implausible reason to deny.
Ok, call me cynical!
Also, the Max 28 Loader is kind of flimsy.
The new Max26 curved beam loader appears to be even more light duty.
So this is Mahinda's warranty Document
http://mahindrausa.com/sites/default/files/misc/2015_Warranty_policy.pdf
Any and all of the Posts/ Photo's I have put online regarding my improvements and use of my tractor effectively killed any implied warranty.
No honor when it comes to $$$$$.
Could be worse, for instance some car manufactures try to deny warranty work if you add floor mats. (Hope I'm joking)
Yup, learn to weld!
The machine has been quite strong and reliable for me. I try to not push it too much, for I need it around. I'm picking up tractor throw tomorrow and will post some pics over the weekend. I'm pretty sure I need new mounting brackets. The cracks are fully thru and around the entire shaft.
   / Mahindra 26 Max XL #8
Look on the bright side, the tractor frame did not crack, just the attachment brackets. There are welders who can make it better than new.
   / Mahindra 26 Max XL #9
I have the same model, with backhoe and MMM. I have 40 hrs now and check bolts every 10 hrs. Only found a couple that were a little loose at the first check. None loose last 3 checks. Been digging stumps, clearing brush, and built 100 yd target range. Very happy with the Max26XL. Checking bolts is easier than welding.
I stopped back to the dealer today expecting to pick the tractor up and take it home to weld. Unfortunately, my lower transmission casing on the right side also cracked off and needs replacement. I guess the loader bracket either mounted into that area or the bracket torqued down and smashed the corner off? The dealer told me approx. another $2,500 (on top of the $2,300). I have pictures which I need to download and send later.
   / Mahindra 26 Max XL #11
Man sorry to hear that, would love to see pics.
   / Mahindra 26 Max XL #12
Ouch, that really hurts! Sorry to hear that
   / Mahindra 26 Max XL #13
Sorry, that is a bitter pill to swallow. Maybe try contacting Mahindra direct, and hope they would sell you parts at a discount.
I found bolts loose on my loader. I was not going to check the Max28 bolting as the only fasteners that ever got a little loose on my +2000 hour hard worked L39 has been a few bolts on the 4 Post FOP. Warning on TBN got me curious, and yes the hard to reach bolts were loose.
Crown SP3550H-30 Stand-On Electric Forklift (A59228)
Crown SP3550H-30...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2018 Ford Explore AWD SUV (A59231)
2018 Ford Explore...
ATHENS PLOW CO. 55-7' DISC HARROW (A60430)
ATHENS PLOW CO...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
