Oil & Fuel Mahindra 1533 had fuel with water in it and I don’t know what I am doing except trying.
   / Mahindra 1533 had fuel with water in it and I don’t know what I am doing except trying. #1
Acethe3rd
Mahindra 1533
Hey y’all. I am a country girl that ended up in the city and the golf course. After my parents passed away I moved back to the farm and now working to get ever thing fixed. My hired hand quit me. Not surprised. Anyway, I have fenced in 16 acres and concreted every post in. Posts were painted then off I went. I love Big Red. My Mahindra 1533 and it works hard. I said it is my husband. lol I guess that is my introduction. Nice to meet all of you. Ace was my sweet Boxer that I rescued so that explains the name.
Ok. Got bad fuel, I was filling up tractor and noticed it. It had water all in it. Horrible. So I have been trying to fix it myself and researching everything. And you are all great. Great advice and nice. So I came here for help. I finally found the manual and it had taken all day. I had drained the silver pump first and drained out of the just about empty tank and put in new fuel with an additive. Tractor cranked and after a few seconds here came the smoke and lights all over the dash. I cut it off and started researching again. I went out earlier and took off the fuel sensor, cleaned it and let what junk was in the line drain out. The plug was off so I plug it up after all of the junk and yellow just came out of black filter. Then I found a line that I don’t have a clue as to where it goes. Here are the pictures. I don’t know if I should clean out lines or call the dealership. I didn’t try to crank it. Emissions light is still on. But here are the pics. So maybe some of you could share some of your wisdom and help me before I call the dealer.
   / Mahindra 1533 had fuel with water in it and I don’t know what I am doing except trying. #3
I’m suprised no one answered this. I’m not familiar with that tractor. Did it run on the bad fuel before you realized it had water. Was it just water in the fuel?
   / Mahindra 1533 had fuel with water in it and I don’t know what I am doing except trying. #4
Looks like silver cannister near engine block houses your fuel filter. After you drained it did you refill the cup or pump the plunger next to it to refill it?
I am too. The tank I had, I had filled up tank on tractor and it ran, it still had fuel in it and when I went to fill it back up is when I noticed the water in the tank.
Yes I did. Plunger got hard to push and that is when I know it is ready to crank. It cranked and that is when I cut it off and then took off sensor, cleaned it, let fuel drain out until it was nothing but diesel. I guess I should have done that first but I didn’t.
Well looks like I will call the dealer. I just knew someone would answer. Oh well.
   / Mahindra 1533 had fuel with water in it and I don’t know what I am doing except trying. #8
I don't think you got all the bad fuel out. The filter could still have water in it. And I wonder if anything else was in the tank since you describe the color as "junk and yellow"..
I run an older tractor - a Massey 1533 that has no emissions or electronic controls. I don't know your tractor but wrote of my bad fuel experience on your other thread.
Understand, I could be way off the mark here. I've only been at the tractor games for 4 summers now. Still learning.
Sorry you are having this bad time.
   / Mahindra 1533 had fuel with water in it and I don’t know what I am doing except trying. #9
I think your 1533 and my 2538 have similar engines. So, on my tractor the silver can is the primary filter and on the other side of the engine is the secondary filter. The secondary has the water sensor at the bottom of the filter. You may want to see if you can remove the wiring connector from the sensor and then unscrew the water sensor to drain out the water. The extra line may be return to tank, the injectors intentionally bypass some fuel back to the tank for cooling of the injectors.
   / Mahindra 1533 had fuel with water in it and I don’t know what I am doing except trying. #10
I just went through this same thing with my 2538 a month ago. You need to replace both filters to be safe , Drain tank and remove filters , Replace filters fill with good fuel , prime and start , mine would run for a few seconds then die, i had to prime several times till it stayed running. good luck
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
METAL STORAGE SHELF W/ 6 COMPARTMENTS (A58374)
METAL STORAGE...
Giyi 72" Box Broom Sweeper (A57149)
Giyi 72" Box Broom...
2025 Future 750 Remote Control Crawler Mower (A56859)
2025 Future 750...
1654 (A58375)
1654 (A58375)
