Mahindra 1533/1538 FEL Curl
   / Mahindra 1533/1538 FEL Curl #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I have zero complaints about the lift capacity on my 1533. However, I've had a few incidents where I couldn't curl. In other words I could lift but couldn't curl. I've never been on a tractor that did that- it's always been the opposite.
Before I go down the custom cylinder route I figured I'd better ask what others have experienced with their 1533/1538s.
Thank you
I posted this in the Mahindra section. They suggested I also post here.
BTW it sounds like this is unique to my machine. In other words other 1533 owners report curl works when lift won't- the more normal FEL response.
I'm going to bump this and provide some clarification.
It appears my FEL curl cylinders are weak. Besides geometry and undersized cylinders (both of which I think have been eliminated since none of the other 1533/1538 owners are experiencing)- what can cause one set of cylinders to be weak? It appears all of my other hydraulics are working correctly.
Any trouble shooting tips would be appreciated.
Thank you!
   / Mahindra 1533/1538 FEL Curl #4
Swap curl lines for lift lines. If problem follows, there's an issue with the valve. If not, a seal in one of the cylinders could be bad.
Great suggestion! I have a post in the hydraulics section- some folks thought it could be a quick connect- obviously that would diagnose that as well.
2005 Toyota RAV4 SUV (A48082)
2005 Toyota RAV4...
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
Holiday Rambler Alumascape Travel Trailer (A48082)
Holiday Rambler...
EZ-GO Electric Golf Cart (A50860)
EZ-GO Electric...
LOOK! (A50657)
LOOK! (A50657)
14ft Flatbed Truck Body (A48081)
14ft Flatbed Truck...
