Mahindra 1533/1538 FEL Curl
   / Mahindra 1533/1538 FEL Curl #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I have zero complaints about the lift capacity on my 1533. However, I've had a few incidents where I couldn't curl. In other words I could lift but couldn't curl. I've never been on a tractor that did that- it's always been the opposite.
Before I go down the custom cylinder route I figured I'd better ask what others have experienced with their 1533/1538s.
Thank you
I posted this in the Mahindra section. They suggested I also post here.
BTW it sounds like this is unique to my machine. In other words other 1533 owners report curl works when lift won't- the more normal FEL response.
I'm going to bump this and provide some clarification.
It appears my FEL curl cylinders are weak. Besides geometry and undersized cylinders (both of which I think have been eliminated since none of the other 1533/1538 owners are experiencing)- what can cause one set of cylinders to be weak? It appears all of my other hydraulics are working correctly.
Any trouble shooting tips would be appreciated.
Thank you!
   / Mahindra 1533/1538 FEL Curl #4
Swap curl lines for lift lines. If problem follows, there's an issue with the valve. If not, a seal in one of the cylinders could be bad.
Great suggestion! I have a post in the hydraulics section- some folks thought it could be a quick connect- obviously that would diagnose that as well.
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
2023 Chevrolet Tahoe FL SUV (A48082)
2023 Chevrolet...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Knapheide Service Bed (A50860)
Knapheide Service...
