Mahindra 1533/1538 FEL Curl
   / Mahindra 1533/1538 FEL Curl #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I have zero complaints about the lift capacity on my 1533. However, I've had a few incidents where I couldn't curl. In other words I could lift but couldn't curl. I've never been on a tractor that did that- it's always been the opposite.
Before I go down the custom cylinder route I figured I'd better ask what others have experienced with their 1533/1538s.
Thank you
I posted this in the Mahindra section. They suggested I also post here.
BTW it sounds like this is unique to my machine. In other words other 1533 owners report curl works when lift won't- the more normal FEL response.
I'm going to bump this and provide some clarification.
It appears my FEL curl cylinders are weak. Besides geometry and undersized cylinders (both of which I think have been eliminated since none of the other 1533/1538 owners are experiencing)- what can cause one set of cylinders to be weak? It appears all of my other hydraulics are working correctly.
Any trouble shooting tips would be appreciated.
Thank you!
   / Mahindra 1533/1538 FEL Curl #4
Swap curl lines for lift lines. If problem follows, there's an issue with the valve. If not, a seal in one of the cylinders could be bad.
Great suggestion! I have a post in the hydraulics section- some folks thought it could be a quick connect- obviously that would diagnose that as well.
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
Char-Broil Gas Grill (A50860)
Char-Broil Gas...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2017 John Deere 650K LGP Crawler Dozer (A50860)
2017 John Deere...
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
