MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Needing some weld magnification at age 69 and wondering if a magnifier lens is available to fit this helmet?
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #2
I took a standard magnifier lens from the local welding supply(LWS) and cut/filed it untill it fit under the clips at each end. Be careful not to take too much off. And make the edges of the ends tapered to a sharp edge to fit under the clips in the helmet.
Do you mean the clips on the inside of the helmet? (shown in pic) I assume that the magnifier needs to go on the inside so as to not affect the lens darkening.
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #4
Yup. Those angled pieces on the left and right of the window. They hold a thin protective cover. Remove that thin piece, and you can snap in a modified magnifier lens.
Use the thin piece as a guide to cutting your magnifier down to size.
Thank you for the info, Dan. Much appreciated.
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #7
I just took a look at one of my helmets (forgot to get a pic) and it had a wire clip that was flexable enough to hold the thickness of a magnifier lens. But before that I had cut/filed a magnifer to just fit under the short edges.
If you take too much off ,like I did once, you can just tape it on.
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #9
I just wear my trifocal ANSI safety glasses under the Chicago hood. Works fine for me. Those glasses even have a top layer of magnification equal to the bottom. Real handy when working overhead on any project. Plastic lenses may be iffy when cleaning slag.
Ron
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #10
taped mine in.
Good idea. I used a 'bigger hammer' for fitting my Lincoln hood.
Carl (woodlandfarms), did you use transparent tape?? If not, what shade?
Terry
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
