Magnetic or Blanket Heaters
/ Magnetic or Blanket Heaters #1
stampede38899
North Carolina
Tiashan Dragon 270
I have a tractor that I dont think the cold start works on. The tractor is very hard to crank in cold weather. Once the tractor cranks it will crank very east from there on out. I was wandering if the the heaters from Northern Tool(magnetic and blanket). They also have one that mounts under the oil pan with 3m tape. I hope in return the block and oil will contain some heat for easier starts. Anyone have in suggestions.
/ Magnetic or Blanket Heaters #2
Magnetic heaters are a joke, and I can't see a real application for a blanket heater in your case. Pan heaters however, effectively thin the oil - which helps increase cranking speed. But the real issue is why the "cold start" doesn't work. And I think you still owe us a few answers from the last time we tried to diagnose this. Didn't we conclude that you had an intake heater? If yes, they're pretty basic concepts to troubleshoot.
//greg//
i had to put a new switch on the tractor and donr beleive it works correctly.
/ Magnetic or Blanket Heaters #5
Well, I guess there's the possibility that you didn't connect the cold start system to the right post on the keyswitch. But you've got multiple issues here. Which to you want to pursue first?
//greg//
/ Magnetic or Blanket Heaters #6
Nothing works better than a block or lower rad hose heater. I have tried them all.
The glue on pan heaters are the next best choice but a magnetic heater is worthless.
Chris
/ Magnetic or Blanket Heaters #7
I have an all hydraulic tractor with something like 28 gallons of fluid. There is no clutch on the pump so the engine starts immediately turning 3 pumps. This is an oil cooled Deutz engine so no option for coolant heater. I used 2 magnetic heaters on the large hydraulic oil tank and a smaller one on the oil pan. It made a huge difference when temperatures got below freezing. Without them, starting the tractor was ugly. So I am surprised that people say they are worthless. I ran this way before upgrading to intake manifold heaters.
Ken
/ Magnetic or Blanket Heaters #9
Magnetic heaters may be a joke but they've worked for me. I bought one when I was having trouble starting a borrowed Satoh. It warmed the tractor enough to make a difference in starting. I later used it on my Ford Van as an assist to the block heater.
Heck back in the '60's we'd put a frying pan under the engine.
/ Magnetic or Blanket Heaters #11
Let me clarify then. Compared to other heating solutions, magnetic heaters are the least efficient. Compared to other methods, there's simply too much free air loss. It takes a very high wattage to deliver sufficient heat. Some hardware-specific blanket heaters (like a battery blanket) can deliver effective heat. They cover the whole device. But most universal blanket heaters only cover part of the device, also wasting heat to free air loss. Conversely, oil pan/sump heaters are the most efficient. They deliver the most direct heat at the lowest wattage. I can heat a 12 quart sump to a constant 125F with one 250w pan heater. Coolant heaters fall somewhere in between, but installation necessarily cuts hoses, and leaks are not uncommon. Plus - because they're immersed in coolant - they have a greater tendency to short out than do other methods. Tank heaters have limited tractor applications. Dipstick heaters are another joke. Yes they're technically oil heaters, but they're inefficient as well (and an occasional fire hazard. More wattage is wasted heating the dipstick tube than is actually heating the oil.
//greg//
/ Magnetic or Blanket Heaters #12
I think you mean air cooled. High velocity air cooled for the cylinders, heads, and oil cooler.
I would consider it oil cooled unless a water cooled engine is considered air cooled for the same reasons. Pumps the engine oil through a radiator/fan setup versus some small engines that are strictly air cooled with no radiator setup. But all of that is just semantics.
Ken
/ Magnetic or Blanket Heaters #14
Ken
I'm just telling it like Deutz tells it to eliminate confusion, that's all. And I presume it's because high velocity air is circulated around and through the oil cooler, cylinder sleeves, and heads instead of jacket water or liquid coolant. Air is the cooling medium, not liquid coolant. Makes sense to me. Worked on many of them, even the liquid cooled V-series.
/ Magnetic or Blanket Heaters #16
To my knowledge, no high pressure air is being circulated within the engine. They spray oil to cool the pistons, etc. The oil is circulated to a radiator which has air from a fan on the alternator blow across it. On my tractor, there is also a fan that blows air across a hydraulic oil cooler. This fan also blows air around the engine itself.
I definitely do not recommend the dip stick oil heaters, at least not the brand I tried years ago. It cooked the oil.
With my conventional tractors, I had real good luck with the coolant heaters. I have never tried the stick on oil pan heater. I might give that a try if I ever have a situation where it seems like an appropriate solution.
Ken
/ Magnetic or Blanket Heaters #17
I'm just telling it like Deutz tells it to eliminate confusion, that's all..
Well, confusion often starts at home. Instead of the typical anti-freeze/water mixture, that engine - and I expect those in other PT models - uses oil. The same oil that's used for the hydrostatic drive, the steering, the lift. 20 gallons of it distributed by 3 pumps. Not sure about the PTO though, looks like that might be electric. Anyway, the engine coolant (oil) flows through a radiator, and subsequently loops via (the equivalent of) water jackets.
As originally stated, it's an oil cooled diesel.
That said, I was unable to determine whether the coolant oil doubles as the engine lubricant oil. I can't help but think that it has a separate sump and oil passages like a conventional diesel. If that proves to be true, a pan heater would help in this case as well.
//greg//
/ Magnetic or Blanket Heaters #18
The one I tried actually coked the oil to it. Never tried another one.
Yep, the dipstick heater has to be too hot with way too little surface area to warm effectively. They coke oil till enough builds as insulation and the element burns out... Bonded oil pan type is the best as it has the largest surface area and most efficient transfer.
/ Magnetic or Blanket Heaters #19
The hydraulic system is separate from the engine system on the PT's. The engine is cooled by the lubricating oil. The hydraulic system also uses motor oil as the hydraulic fluid but it is kept separate and typically lasts for many years with just topping off.
Ken
/ Magnetic or Blanket Heaters #20
On the Deutz engine: If it has a large double belt driven fan and ductwork around the engine - it's air cooled. And yes, it will have an oil-to air heat exchanger (you call it a radiator). Oil circulating in cylinder cooling jackets is something I'll research further.
