Magnesium Chloride tire ballast
   / Magnesium Chloride tire ballast #1
gates
Maryland
JD 6410 Cab MFWD & FEL,JD 4610 MFWD & FEL,JD 4720 Cab MFWD & 400CX FEL ,Kub. RTV 900W,Hon. Rincon w/plow,Yam. Grizzly,Case 1845C,580L,580SE,Terex 636,Grasshopper 428D,Takeuchi TL 150,Brush Bandit 150
Does anyone have any information about using magnesium chloride for tire ballast.
Ron
   / Magnesium Chloride tire ballast #2
I`ve not known of anyone useing the Mag chloride in tires.I did some research and found it is being used as deiceing agent in some states.It`s corrosive and when hot the corrosiveness increases so will reguire useing tubes to protect rims.
   / Magnesium Chloride tire ballast #3
If I was looking for a tire filling agent, I'd look real hard at RimGuard, a non-corrosive fluid that weighs about 10 lb. per gallon, as opposed to most water based metal/chloride solutions that come in near 8 or 9 lb per gallon unless you really make them strong and thus more corrosive. Windshield fluid is lighter due to the alchohol content. I understand that rimguard is beet juice. Others here probably know for sure.
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
