made the plunge
/ made the plunge #1
Mike5b1
Kingston ish Ontario
LS xr4140
thanks everyone for all your posts, knowledge and insight, it sure helped to me to sift through the overwhelming amount of info on all the brands and models. My Wife and I just purchased an
LS XR 4140. delivered today. the choice was between an XR3140 or the 4140. while the 4140 is a little big for what i need at the moment but i followed the golden rule of tractor buying.
We went Blue due to the fact that out of all the dealers in 1.5 hour drive, only 2 actually let me get in the thing and let me take it for a spin. Those 2 where a NH dealer and the LS dealer i purchased from. the sales guy from the green guys [ who my family and I have dealt with for decades], was almost ashamed of the price that he offered me. fine machines but more features then what i need. ANYWAYS, not looking to open a debate, just my experience. Again thanks everyone.
/ made the plunge #2
Welcome and congrats! And a back hoe to boot. A nice ride you have there. You know that you're required to post pictures where the tractor has actual dirt on it? Subsection 3. So get out there and get some at least dirty slush on it :)
/ made the plunge
there is dirt on this one i swear... went and cleared some snow banks and almost got it stuck,,, forgot that I didn't put ballast in the rear because of the back hoe and the lawn, figured that would be a bit heavy for the time being. Good thing measured before i put it in there.... need feeler gauges to measure how tight it is to the top but not touching:drink:
/ made the plunge #4
Congratulations!
That is a fine looking machine!
/ made the plunge #5
G'day Mate and welcome to TBN from Downunder.
Just get yourself a ballast-box (or make one... there're plenty of threads here on TBN of what Members have knocked-up) for those times when the backhoe isn't on. As you've learnt, it's best to have your machine balanced for the work you're doing.
Congratulations on your new rig and enjoy the site.
/ made the plunge #6
You don't need "extra" weight on the back end ..... just put the backhoe on. Nothing is better for getting "unstuck" than a hoe that you can use to push or pull yourself out of trouble.
/ made the plunge #7
That's a tight fit for sure. If you leave in there during a heat wave, probably too much tire pressure to get it out! Of course, there is the frost heave... Ditto on a ballast box. I made one for my little LS with a tool box in the top and a place to slide some shovels and rakes into. There are a few good designs on TBN to poach from.
/ made the plunge #8
:welcome: to TBN and congrats. As said, make yourself a rear ballast box. Cheap and easy to do.
/ made the plunge #9
Congrats on your new investment. :thumbsup:
Your project list will get longer but much easier to do. ;)
/ made the plunge #11
I have a XR4150 and love it. Also backhoe. tires are all full. and it is a lot more weight. But the light work I leave to my son on his little 26hp. You can also leave a box blade on the back. I have one with saddle weights hung on it. What ever way you go, it looks like you will have to take it off to get it inside. Good luck,
/ made the plunge
Ya i can use the Hoe for weight, but i also want to be able to haul wood to. so i think i will build a ballast for the three point that incorporates a 2 inch receiver. i have a trailer that is fairly well balanced without a ton of tongue weight as long as you load it right, so i think it should be fine pulling it with the 3 point.
/ made the plunge
congrats on the Mt! i do love my ls so far. only 10 hours on it so far though, but its been buried in mud and done some good fire wood action so far. I cant wait for spring to get on with it and the frost to go away!!
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
