Made some FEL stands and started tye removal to adjust clutch on my 1710.
   / Made some FEL stands and started tye removal to adjust clutch on my 1710. #1
Nolo263
1986 Ford 1710
I welded up some stands for my fel and removed the loader. Hopefully tomorrow i can get the bolts loose on the loader frame. The right side bolts broke loose easy but the left side are tight as ****. Tomorrow I will try with an impact. Im scared to break the bolts! I will adjust clutch if i can get them off! Does anyone know the torque on the loader frame bolts?
Forgot to add if anyone needs specs to FEL stands. They are 36" high and 19" for 1" round bar.
Update got loader frame off and removed inspection cover adjustment was about 3x what it should be. I adjusted back to .035 and pto engagement is perfect now! Now to check every bolt and look for anyything bad and put it back together!
   / Made some FEL stands and started tye removal to adjust clutch on my 1710. #3
Looks like those stands work well. Glad to hear you got it all squared away.
48" QUICK ATTACH PALLET FORKS (A52707)
48" QUICK ATTACH...
BUNDLE OF 8" GALVANIZED PIPE (A57192)
BUNDLE OF 8"...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
