Made my Kubota pee
/ Made my Kubota pee #1
PAB_OH
Platinum Member
Carroll County, Ohio
Kioti CK30 HST
Well it took less than an hour of run time and I've already broke something on my GL-21 /forums/images/graemlins/blush.gif
I was playing with the FEL last night, scrapping the drive in some rough spots and decided to do some "off roading" /forums/images/graemlins/grin.gif The loader installation was less than perfect and one of the hoses hung down below the bottom of the tractor a little bit and wasn't fastened securley to anything to prevent it from being grabbed by those massive lugs on the front tire. Sure enough, I got in some heavy brush and I think a briar or something grabbed the hose and pulled it into the tire. The tire in turn grabbed it and de-coupled the quick connect. I think the sudden closing of the coupler caused hydraulic hammer and blew the guts out of the female side of the coupler.
I got it up onto level ground within a few seconds and killed the engine. Spent the rest of the night hunting down new couplers. Finally got them from a friend who works at a local factory and they use them in their hydraulic circuits.
So now I'm going to design a port block and hard pipe as much as I can then shorten the hoses and make brackets to hold them all in place.
I'm going to have to pick up a new filter tonight and some fluid. I don't know how much this thing takes so it'll be a shot in the dark. Does anyone know if the sight glass on the back of the 3 point hitch is a good indicator of if the system is at an optimal fill level? Or is just there to monitor and make sure it doesn't get dangerously low?
I'm such a newbie at this stuff it's pretty embarassing. /forums/images/graemlins/tongue.gif
/ Made my Kubota pee #2
I haven't "removed" any hydraulic lines yet but currently we are clearing our property and I managed to put a 1" sapling through the front grill! /forums/images/graemlins/blush.gif
/ Made my Kubota pee #3
I don't know for sure on the gl-21, but the center of the site glass should be the best place to be.
jb
jb,
Thanks for the advice. Right now I am all the way up in the sight glass and that is after is leaked about a gallon on the ground.
I emailed a company in Japan that has two GL-21's in stock and asked them to locate me some manuals. They said they would try so with a little luck I will have some in a month or two. Then I'll probably have to have them translated.
/ Made my Kubota pee #5
When checking the fluid level on tractors equiped with a loader the hyd. cylinders need to be retracted all the way so you want get a false reading.
BOTAMAN,
thanks for the advice also. Is that to make sure you don't put too much in the system?
For example, if all my cylinders are extended and I fill the system then I retract all of them that would overflow the resovoir, correct?
What about the opposite? What if I don't fill it enough?
For example, I fill the resovoir with the cylinders fully retracted then I extend them all I would need a minimum of .5 gallons for the volume of the cylinders(4 cylinders onloader @ 1.75" diameter x ~12" stroke = ~.5 gallons). I guess that's not as big a concern as putting .5 gallon too much in, is it?
Thanks again.
Claas Lexion 450/460/465 Combine Service and Parts Manuals (A63117)
Claas Lexion...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
more info coming soon (A61569)
more info coming...
TAYLOR 24 BLADE OFFSET DISC HARROW (A63291)
TAYLOR 24 BLADE...
