wetstuff
After bouncing around for about an hour: when the front went up - the rake dug in. I could hold some motocross races here. I have a JD-1070 on turf tires and was pulling one of these.
I have a proper, pull-behind, Road Grader but every thing is basically flat now so I was simply dressing the top with (I think he called the stones) 75s. The drive is 1/4mi + so I made a right mess of it.
I dumped the rake and rigged a Drag with a section of chain link fence with a pair of 6x8's at either end. I found they floated over the 'whoops', so I started to add some 12x12 concrete pavers in the middle. ...that was better.
I suspect one of you will wonder where the grader is? ..it's here, but it needs a second person to play Tonka Toy on the grader and does not have front wheels, so the grader is not totally independent of tractors gyrations. ...and with a FEL in front and the grader well out back, it is long as **** and no fun to back-n-turn. My drag just requires some Polish determination and about a 6 foot radius.
I am here because I'd bet one of you has already wrestled with this, so I've come for some insight. Thanks.
Jim
...btw - if you have a long drive, look for one of these old graders sitting in some woods. More fun than drill with a light in it. I drove by this one for 20yrs before I bothered to ask.
Jim
