M9540 clutch question?
/ M9540 clutch question? #11
Running it without the clutch pedal returned, will most likely cause premature throughout bearing wear...
Just like holding your foot on the clutch, it's does the same thing.
SR
/ M9540 clutch question? #12
SR
I thought most of these newer machines used a continuously running throw-out bearing ?
/ M9540 clutch question? #13
Traction clutch control pedal not fully rising to top of travel could possibly shorten life of the dry traction by not allowing pressure plate to apply designed pressure to the clutch plate. This will depend on how far from fully raised clutch pedal is after operators foot is removed from pedal.
Oh boy is that an understatement ! I had a MF2660 brand new with dorked up [8 speed shuttle shift] clutch linkage such that the clutch pedal never fully came back up. That was made worse by a manufacturing defect where the pedal lever scraped against (and was impeded by) the underbelly of the console. I had no idea there was a problem and being brand new was still on a learning curve with it as well. Result was it burned out the clutch. The tractor had to be broken in half for a new clutch installation at 29 hours.
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2015 Chevrolet Tahoe SUV (A61569)
2015 Chevrolet...
2013 FORD F250 (A60460)
2013 FORD F250...
