M8540 hyd shuttle cable
   / M8540 hyd shuttle cable #1
big bubba
Elite Member
arkansas
M8540
for those MXX40 hyd shuttle owners. had my hyd shuttle cable replaced around 600 hrs due to sticking & not being able to fully engage forward/reverse motion.
currently 825 hrs, no prob. access to cable is complicated (dropping fuel tank, ect) & had dealer do it. anyone out there have any advice on how to access the cable for lube on either end? sure wish the cable had a oil nipple or zerk to lubricate. the tractor is covered most of the time. think the answer is no, but thought i'd ask anyway, regards
ok thanks, will keep in mind. replacement w/labor was around 1k, so will look into it. regards
   / M8540 hyd shuttle cable #4
Basically, it's an aluminum outer body with a rubber inside body and you clamp it on the end of the cable and use motorcycle chain lube in a pressurized can (with the straw) to inject it into the cable. I use it on a lot of different cables as one size fits all. Works on tach cables too.
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
2024 Bobcat E35 Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Bobcat E35...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2019 Club Cadet ZT1 54in Zero Turn Commercial Mower (A50322)
2019 Club Cadet...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
