M7060
/ M7060 #1
FarmerMel
Kubota m7060
My kubota m7060 is loosing power after an hour or so of operation when under load. (Rolling hay). Any help appreciated.
/ M7060 #2
The engine rpms decrease? That is, it’s not a transmission slip problem?
I’d check the simple and cheap stuff first.
Is fuel cap venting? Next time it starts to die, loosen cap and see if rpms increase.
Something in the fuel tank that moves around and eventually blocks fuel line?
New fuel filter? New air cleaner?
/ M7060 #3
Does the temperature go up? That would indicate to me a plugged fuel filter.
/ M7060 #4
I believe there is a known fuel injector issue with a fix as fail program. Check with your dealer.
Might be your problem.
  • PSB-2021-007_page-1.pdf
/ M7060 #5
Mine had that fuel injector issue last year. It was covered under warranty. Good luck!
