M7060 Cast wheels at wider setting pics
   / M7060 Cast wheels at wider setting pics #11
dualies are another option, wider and more traction!.
   / M7060 Cast wheels at wider setting pics #12
Never seen a Kubby with duals. Guess there is always a first time but saying that, the axles themselves aren't long enough.
   / M7060 Cast wheels at wider setting pics #13
HUH!!! My owners manual say to never run duals..........
   / M7060 Cast wheels at wider setting pics #14
I just found out that Kubota's have notoriously small axles, and they break with duals, the wheels have to slip a bit on them..:eek:
   / M7060 Cast wheels at wider setting pics #15
there's many pictures of them running duals, it don't have anything to do with axle length, they mount with the bulging side to each other, just like on an 18 wheeler.. but don't do it, the axles are too weak compared to other make tractors..
   / M7060 Cast wheels at wider setting pics #16
Maybe on smaller Kubotas. The rear axles on my 2009 Kubota M6040 - 4" diameter.
   / M7060 Cast wheels at wider setting pics #17
On a big truck (or on my goose neck as well, the inner rim and the outer rim (duals) mount to the axle, not to each other.
   / M7060 Cast wheels at wider setting pics #19
Like I said - the rear axle is 4". The flange is 10".
Toro Reelmaster 6500 D (A57453)
Toro Reelmaster...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2021 RAYCO C120RA FORESTRY MULCHER (A52709)
2021 RAYCO C120RA...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
