m7060 cab model wire routing question
/ m7060 cab model wire routing question #1
RoyKing
Platinum Member
Gainesville Florida
M7060HSC/18, RTV-X1100C
Since I'm old and fat maybe somebody can save me some time with routing the wiring into my cab from the FEL. After spending a little time with pallet fork it is kind of obvious a second person is needed because you can't see what you're doing. So I bought a backup system with two camera's.
My question is routing the coax wire from the front into the cab, I know there are grommets at the rear of the cab, and unused power plug behind the seat.
So I'd like hear what routes others have used to keep the cable safe and into the cab. I'm going use some of those 40lb pull magnets to mount the camera and move them around for different attachments.
Thanks in advance, pics would be nice
/ m7060 cab model wire routing question #2
Here is what I did. I have no pictures, but might be able to take some later today. I used magnets for the cameras as you suggest. I currently have the front one on the grill guard. I'm still in winter mode and have only used it with the forks once, so not much experience with it yet but it does help. Mounted on the loader might be better. I brought the camera cord in under the right side of the cab where the cables for the loader valve come through the floor. From there I took the floor mat out and removed the "tunnel cover" and ran the cable under that and up under the dash and came out to the monitor which I mounted on the grab rail to the right of the dash. I spliced into the cigarette lighter wire (switched power) for the monitor and camera power.
Thanks, and if you get chance a pic of cab mount would be appreciated
/ m7060 cab model wire routing question #4
So after multiple tries I have determined I am no longer smart enough to post pictures to this sight. I give up.
I got a RAM Mount that has a U bolt that clamps around the grab handle, and the monitor is mounted to that.
(2) UNUSED 27X8.50-15 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2006 Ford F53 Landau 3645DS 36ft. Class A Motorhome (A61574)
2006 Ford F53...
2018 Nissan NV200 Cargo Van (A61573)
2018 Nissan NV200...
2015 Freightliner (A64119)
2015 Freightliner...
