M7040 "hissing" noise from under seat?
   / M7040 "hissing" noise from under seat? #71
Your exactly right! I will show them how it handles it when I'm mowing my hills with my duals on lol
I will post pics for the "safety patrol"
Batwing and duals,they are going to have a field day with that:laughing:
   / M7040 "hissing" noise from under seat? #73
Thank you! And at 4.27feet per pro HP I wouldn't at all say that is "hugely oversized"
I think your math is incorrect. 4.27 X 65 =277.55. I think you meant 4.33 HP per foot of cut
That's right, I was figuring it at 64 pto HP instead of 65
   / M7040 "hissing" noise from under seat? #75
So is all the math adding up to your tractor being properly sized to the needs of the Woods HD315? I'm just curious- I didn't realize your Kubota was as high HP as it is, looks smaller in your avatar. Obviously you can run what you want - I thought there might be a correlation to the size of the batwing and the noise issue of your K'bota.
Yeah the math is close enough to not matter, that's ok just a simple misunderstanding
   / M7040 "hissing" noise from under seat? #77
The thing that would concern me if it was my tractor is my M7040 operators manual states "dual wheels aren't approved"
Not a problem at all, there are a lot smaller tractors with duals on, the manual also says to not use 2 hydraulic funtions at the same time, grease everything every ten hours...... I guess some people stop in the middle of a field to grease up instead of doing it before getting started
There are also3 other M7040's in my area that run duals with no problem at all
   / M7040 "hissing" noise from under seat? #80
It's your tractor so you can run duals if you chose. Irregardless to what you think duals put more strain on the axles & brgs. It's your nickle so drive on. What page in operators manual does it state not to use 2 hyd functions at the same time??
2010 Chrysler Town and Country Touring Van (A50324)
2010 Chrysler Town...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50323)
2006 Imperial 14Ft...
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
New Holland 5 HP Hit And Miss Engine (RUNS) (A50774)
New Holland 5 HP...
