M7 training
/ M7 training #41
I think engine design and coolant flow have also improved.
Several years ago I put a Ford 400M V8 in my Jeep Wrangler. Bought the biggest 4 core aluminum radiator that would fit. Mechanical fan with 16" electric fan in front and still couldn't cool it when wheeling. :)
/ M7 training
I've learned that it's not so much the number of rows but the size of the tubes and the amount of coolant flow. I had a 2 row aluminum radiator with 1 1/4" wide tubes in my hotrod and the thermostat stuck open, it wouldn't get above 130 degrees and that was with 100 degree ambient temperature.
/ M7 training #43
I believe you are looking at the hydraulic oil cooler in front. Radiator is the last in the stack prior to the fan, and it n front of it the hydraulic oil cooler, AATAC, and air conditioner condenser.
/ M7 training #44
Yep. That was my point. They are so efficient they can be stacked. Worst part of that design is cleaning them. If they aren't on sliders it is a challenge.
On the JD grader I run they are not stacked and the fan is hydraulic and automatically reverses for 10 seconds every 30 minutes. They never need cleaned.
/ M7 training
Everything swings up on the M7 so you can get to the radiator for cleaning.
/ M7 training #46
Awesome!!!
/ M7 training
Here we are with the M7 hooked to the dyno. It made 142hp at 580 PTO RPM. With the throttle turned down to 2005 RPM/540 PTO RPM it made 110 HP.
Brian
Club Car (A59231)
Club Car (A59231)
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
(INOP) WHITE 2-180 TRACTOR (A63291)
(INOP) WHITE 2-180...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
iDrive TDS-2010H...
