m610 hydraulics jumpy
/ m610 hydraulics jumpy #1
tools
allis chalmers wd45
Just rebuilt a m610. Had ALL the hydraulic parts off and rebuilt one cylinder.
The lift and tilt are jumpy going up. Going down, even pressure down, seems better. There was LOTS of air in the fluid, very foamy, when I checked it. I added more and that helped some, but don't think that's the problem.
Is there a procedure for bleeding? I've cracked lines here and here and get a little spurt of air. The bucket is somewhat spongy when up, also indicating air in the lines. The fluid that comes out when I crack the lines is foamy as well.
I'm using 303 hydraulic fluid, is this wrong?
Thanks,
Mike
/ m610 hydraulics jumpy #2
Thanks,
Mike
to get rid of air in the cylinders youre supposed to operate the rams to there full extent and keep operating them for ten seconds in both open and closed positions, however it sounds like your fluid is low or it is sucking in air before the pump somewhere.
Jim
/ m610 hydraulics jumpy #3
Check all suction line connections, sounds like you're getting air through a connection. loose hose clamp, etc.
Deere 310SK (A57148)
2013 Freightliner M2 TA45M Bucket Truck (A60352)
2013 Freightliner...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
EXCAVATOR COUPLER (A60736)
EXCAVATOR COUPLER...
Viewz VZ65UHD 65in 4K Security and Signage Monitor (A59231)
Viewz VZ65UHD 65in...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
