M6060 Emission fault light
   / M6060 Emission fault light #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
Guys worked the tractor hard yesterday and today... This morning I noticed the red light on the dash turned on. It was showing an emission fault. Tractor was running perfect but decided to head back to barn and check it out..
I was hoping a loose wire or connection around the DPF. After close inspection, I found a rat had chewed a hole through a rubber hose coming off the DPF. I had some old fuel line laying around so 10 min and it was fixed..
Man I was sweating it.. thinking the worse...
It ran the day before fine so rat must have done the damage in the night hrs... Any idea what this hose does? Sensor ?
Just a reminder to inspect the tractor before you call a mechanic.
   / M6060 Emission fault light #2
The part can be seen under the Engine section of the parts drawings. See 378400 MUFFLER SENSOR
Part Description
SENSOR / SENSOR
Part Number
1J520-18600
Stock Status
2 in stock
Messick's Price
$192.36
See item 50 in the attachment
  • Muffler Sensor ku-96500-238889-609218.pdf
Part Description
SENSOR / SENSOR
Part Number
1J520-18600
Stock Status
2 in stock
Messick's Price
$192.36
Hey, thanks for looking it up.. Figured it was some type of sensor..
I got lucky on this one...
2018 CATERPILLAR 289D SKID STEER (A51242)
2018 CATERPILLAR...
(8) 75 lb IH Suitcase Weights (A50515)
(8) 75 lb IH...
UNUSED FUTURE PAIR OF MINI 7" RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
2020 MDB UT125KPLUS FLAIL MOWER (A51243)
2020 MDB...
