M60 Tank Can't Keep Battery Charged
   / M60 Tank Can't Keep Battery Charged #1
4tillingdirt
nc
N/A
I have an M60 Tank with the 23 HP Kawasaki engine. It has a little over 500 hrs and the clutch started not wanting to engage so I adjusted the 3 screws on the clutch so it engages most of the time - sometimes have to rev engine. Problem is I just put a new battery in and either the clutch is draining the battery or it isn't charging properly. I have a multi-meter so I guess I need to start checking and see how much voltage it is putting out when running?
   / M60 Tank Can't Keep Battery Charged #2
Serious, you have one of these?!?
   / M60 Tank Can't Keep Battery Charged #3
One of those, with 23hp, would be overworked a bit on the hills.
Bruce
   / M60 Tank Can't Keep Battery Charged #4
An M60 ... how cool is that?!?!?!
   / M60 Tank Can't Keep Battery Charged #7
Lets not scare him away while we are having fun.
Probably one of these.
Bruce
Bummer, but that still looks cool.
OP: Check the voltage at the battery when the engine is running. It should be about 14vdc. If not then check back up the charging circuit.
-R
Yep reading 14.3 volts. I am going to adjust on the clutch. I think the gap is too large because when I mowed the other day it would crank but I could tell the battery was weak. After I finished mowing it wouldn't start.
do you measure in the slots that are directly above the bolts - .015?
   / M60 Tank Can't Keep Battery Charged #10
What is the battery voltage with the PTO engaged?
Sounds like you might have some shorted turns in the clutch causing high current usage.
Richard
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A52748)
2016 RAM 5500...
1992 JOHN DEERE 544E (A52472)
1992 JOHN DEERE...
