M59 Wire Routing
/ M59 Wire Routing #1
pepper66
Kubota M59
Have an M59. Wiring under floorboard not correctly installed from a previous repair. I have repaired the loom in a few places and reinstalled it. Could someone get a picture of the routing. Looking left to right seems to be the best angle.
Would be greatly appreciated.
/ M59 Wire Routing #2
/ M59 Wire Routing
Thanks for the reply.
I bought the machine used, and whoever worked on it did not reinstall the wiring loom correctly. I partially removed the loom that was not fastened at all. I repaired the damage wiring and removed some previous shoddy repairs. I found the proper wire ties and installed the loom the way I think it should be routed. After looking at it for a while I'm not sure it's right. The Kubota WSM does not show many clear pictures of the loom routing.
/ M59 Wire Routing #4
If you post a photo of your area in question I can see if I can get some shots from mine.
/ M59 Wire Routing
mikester
The first two pictures are taken from the left side of the machine looking right. The third is from the rear by the quick couplers looking forward.
/ M59 Wire Routing
Sent the same one twice. Here's the other taken from left side 20181121_072202.jpg
/ M59 Wire Routing
Got a WSM but the few pictures it has really don't help. Stop at a couple of dealers, not many similar machines on the lots. Still looking for help.
/ M59 Wire Routing
mikester
Do the pictures help any ?
Thanks
2006 Genie Z45/25J Articulated Boom Lift (A64047)
2006 Genie Z45/25J...
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
Black Walnut Lumber (A61166)
Black Walnut...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
Honda Rancher 300 es (A64047)
Honda Rancher 300...
