M59 front hydraulic question
/ M59 front hydraulic question #1
Hersheyfarm
NE ky
How does it operate? Mine is a push button. If I ad one of those claws can I pick up a roll bale? After you push close button what keeps pressure on it. What other attachments do people use up front?
/ M59 front hydraulic question #2
By claws I assume you mean a grapple of some sort. Once you close the jaws, if you need to maintain constant pressure on the object you have to hold down the button. I think some grapples have double check valves or non-return valves to maintain constant pressure, but that might be only for bale grapples or timber grapples. Either way, if you're only going to pick up round bales there are purpose built spears and even round bail grapples for that.
As far a other attachments go...you can run harley rakes, rock hounds, snow throwers, 4-in-1 buckets, flamethrowers ;) etc.
-Mark
/ M59 front hydraulic question #3
push the button and it puts pressure on one line and put the other to tank, push other and just the oposite. when you let off button it holds the pressure in the line which keeps the implement from moving after you let off the button.
So the button is an on and off. Does it slam a grapple shut because there is no proportional lever?
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2004 International 7400 C&C 017797 (A62613)
2004 International...
2014 Caterpillar 308E2 CR (A64126)
2014 Caterpillar...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
