M59 Breakdown and Repair
   / M59 Breakdown and Repair #11
Hi rScotty
I too thought about purchasing a used full size machine to get a cab before I got the L45 but in the end I decided I didn't want to deal with trailing a large machine as I do a lot of side jobs in the summer so my L45 moves around a lot. I almost purchased a used 2008 M59 with 500 hours on it which already had the Laurin cab on it as well as front remotes and the backhoe thumb. Unfortunately I read a few posts about guys having expensive hydraulic pump problems with early M59's and that made me nervous so I opted for the L45 instead.
I am glad you have a machine with a cab rScotty. Years ago I was in logging and used to work in the northern Ontario bush in temperatures up to -40 degrees but I can no longer take the cold. There is nothing like pushing snow in a raging blizzard in a T-shirt!
Thanks for the tips on the cable - I will check mine out this weekend. I use auto-throttle all the time so there may be some issues with mine too. In fact I use it so much that during the fitting of my snow blower last fall the dealer kicked the switch out of the Auto-throttle detend and it took me a few minutes to figure out why the engine would not rev when I stepped on the HST pedal.
Regards,
Lauren
Darn....I must have missed those M59 posts. And I have one of those early M59s!@ .Although maybe that's a good thing as it has turned out OK. A hydraulic pump problem is a new one on me. If you still have links to the posts please send them along.
I had heard that many of the early M59s sat on dealers floors longer than expected. My dealer said the M59 made its debut at the annual Kubota dealer's convention where a special deal was offered to dealers placing orders. Since times were good, dealers ordered lots. Then just a few months after delivery came the famouns 2008 downturn in US economics......So the machines just sat.
Ours is one of that early lot, but I haven't heard about a pump problem. So far if I had to choose between the 310 and M59.... the nod would go to the M59 for usability and to the 310 for operator comfort.
rScotty
   / M59 Breakdown and Repair #13
I don't doubt some day there maybe a cab on the M59. Its been a long requested feature and Kubota seems intent on strengthening its position with commercial operators.
   / M59 Breakdown and Repair #14
I guess it had to happen. After six years of working something finally broke on our M59. This machine is used for a lot of short chore work and has about 600 total hours. These tend to be hard hours but not high RPM hours. We don't idle much, tending to run with the Stall-Gard feature activated but with the Low/High auto shift feature not engaged. This combination works the auto-throttle pretty much constantly.
So I was pushing a load of flood debris - rock and dirt - when the HS foot pedal suddenly felt different and the engine dropped to an idle. Investigation showed that the wire cable running from the engine governor to the auto-throttle lever had broken. Actually I was glad to see that. My fear was that it was going to be something in the transmission or the magical software/electronic controls. A broken cable is something I can deal with....it being a typical control cable about like a motorcycle throttle cable or bicycle gear shift cable.
Luckily - or due to good design - the M-59 auto-throttle cable runs in parallel with the hand throttle cable so the tractor continued to work in manual throttle mode until the part arrived. Not a whole lot of difference really, and none at all as a backhoe.
I called Messick's part dept. and the pre-made cable came UPS about 3 days later. It has a different plating on the metal parts than the original, but otherwise it's the same high quality part. Sporting the proper type of multiple strand cable for a flex application, regular even crimps, good rubber - not vinyl - in the dust protection bellows, wire connection looks right, no extraneous solder creeping up the wire strands....all things that this old mechanic looks for in a pre-made flex cable. Roughly $30 plus postage. Postage was high, so I took the opportunity to buy a couple other cables just in case.
Replacing and readjusting the new cable should have been a one hour job but took twice that long because the cable routing is so difficult to access. Major POA, actually. Other than access, the installation was straightforward for anyone having tiny hands equipped with double jointed steel fingers. And possessing U-joints in place of the more common type of wrist, elbows, and shoulders.
I wanted to get this info out there. We haven't had many posts about Kubota repairs and even less on the M59. This wasn't a case of dirt or adjustment or lack of lube, overuse, or any of the traditional causes of preventable failures. In fact this cable is sealed against dirt. This cable is simply a stranded wire that has to bend to do it's job and it gets to bend a certain number of times before breaking. My guess is it simply reached it's design life and parted. It's working normally now.
rScotty
An obvious design problem. If youre good with it fine, but no correctly designed application should fail in 600 hrs doing the normal job its designed for. You are a highly desired customer blaming yourself. Im sure Kub loves you.
larry
larry
Interesting comment, Larry. I'm sure Kub does so far.....but not so sure that they will if they read this. Having designed equipment myself for 40 years I am well aware that no designer can anticipate all eventualities and of course we all do make mistakes. So I'm inclined to be lenient to start
To my way of thinking, the big mistake was in making the control cable replacement so difficult to access. It looks as though the cable was installed BEFORE the cab floor was put on. Of course the order of assembly is a manufacturing engineer's decision and although the design engineer can over-ride that, doing so means that the engineer would somehow be aware of what manufacturing is up to........not always an easy thing to find out.
And keeping your alleged "Kubota Love" intact is going to depend a lot on how they respond when they recognize this or any items that need to be improved. I'd say it's not about the mistakes, but about how ready they are to fix those mistakes.
So far their response record at that is spotty.
Getting more technical for a minute, my initial thought was that 600 hours is a reasonable lifetime for a cable end moving through a significant bending angle that often. Darn, if we knew the additional tensional stress it gets from pulling on the governor we could evaluate this design in short order because control cable technology is pretty mature now that it has been used for over 50 years in everything from airplanes to bicycles. On reps alone though we can at least do something...lets see...that would be about six to ten times a minute and 60 to an hour....Well that's about a quarter million cycles and yes - now I find I do agree with you; a quarter million cycles does seem too low a number. Unless the governor's tensional stress is lots more than I thought, I'd have expected to get a million cycles at least. A million being a sort of magic number for bending reps in manufacturing.
Although a sample size of one doesn't mean much - except to make me feel a little better about the replacement cable because the life was so short that it's possible I just got statistically unlucky with the first one. To compensate I'll buy a lottery ticket next time I go to town. But for real info we'll have to see if other owners have the same problem. That might not take long. It wouldn't surprise me to find Kubota using the same control cable technology across the board.
Like every mechanic that ever was, I never fix anything without spending some time thinking about how I would have designed it myself. In this case I'm not sure. That looks like just about everything that can be done to a control cable that I know about. It is absolutely sealed, multistranded thin wire, permanently lubed, and the end is fastened mechanically rather than soldered. All the stress-relieving shapes are in the right places, the choice of materials looks good, the ends are compressed well. If it breaks again I'll put some real thought into mounting the end in a bearing or changing over to an electrically driven servo system. Unfortunately the required distance is just too far for using a solid control rod.
rScotty
I disagree. I contacted several dealers last fall and again this spring and had them ask Kubota that very question: Were there any plans for a cab for the M59?. I did what I could to check that the my question got to the proper Kubota representatives. My question included an an offer to pay any reasonable price for a prototype cab, or to help to adapt an existing Kubota ag tractor cab, and even to help Kubota with their design. I've a lifetime experience in engineering design and that was also included.
The one reply I got back was from the West Coast and said that after checking back with the factory they had no plans to offer an M59 cab and also had no development program to design such a cab.
BTW, I also see no evidence at all to support your contention that Kubota is "intent on strengthening their position with commercial operators". Nor do any local dealers support your viewpoint. What are you basing your opinions on?
Our JD310 with an air-conditioned cab is nice, but the technology is older. As I've said before, I actually prefer many features of the M59 Kubota and use it by preference when I can.....that's surprising since the JD is at least 2x the cost.
Scotty
   / M59 Breakdown and Repair #17
rScotty
Good analysis. Where exactly did the cable fail. Did it break clean or fray? Is the design complimentary to multi strand cable such that only pull forces are called for, or is it push pull?
larry
disassembled.jpgauto throttle_ transmission end.jpgAuto throttle_governor end.jpg
larry
Pics: disassembled after end of cable, after end of cable before disassembly, governor end of cable.
Thanks. Yes, you have a good question. This is a multistrand cable used only for pulling forces. Return forces are supplied by springs at the other end within the governor. The unbroken end pulls on a drum to rotate the governor. Connection there is around a about a 4" diameter drum that is large enough so that bending is small.
The after end that broke is within the rubber bellows and it broke cleanly inside that bellows about .01" from where it is compressed into the bronze aft ring eyelet. That's the eyelet that surrounds a pin on the end of a lever leading into the transmission. The broken end did fray, but because the breaks are all on the same perpendicular plane to the cable it looks to me like the cable frayed as a result of the successive parting of the strands at the high stress location. see pics.
When I took a look today I noticed signs of galling on the inside of the bronze ring eyelet. That would seem to indicate that the eyelet didn't rotate freely on it's pin and of course that would increase the bending of the cable wire. Looks like that may be the cause. That area is accessible for lubrication - with some difficulty, but accessible. If it had gotten a few drops of oil from time to time it probably would have lasted longer. Now that I'm looking at the galling of the eyelet it makes me think that's all it needed.
Thanks again. Great question, Larry! It might have led us to a cure - at the least improved things.
rScotty
   / M59 Breakdown and Repair #19
View attachment 373700View attachment 373702View attachment 373703
rScotty
I think youre right. Also it would be good to know if the lever CAN push, or only pull and relax.:confused3: .... As for alleviating the issue in present form, the best lube I know is Militec. Its a surface modifying lubricant that seems to impregnate the surface and have lasting effect. An oil, or put a couple drops into light grease. To ruggedize the stress riser area next to the crimp consider solvent clean and apply a drop of Loctite Wicking compound. This should lock the strands together for a short distance out and ease the stiffness transition.
larry
   / M59 Breakdown and Repair #20
maybe some divisional differences. Cabs are a bigger deal for us in the North East than any other division. The opinion about its necessity may vary. If you are so interested, i do believe there are aftermarket options. We've done them on the L45, but not the M59.
Mini Excavator Attachment Set (A50121)
Mini Excavator...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
New Bobcat 18" Bucket (A50774)
New Bobcat 18"...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
